03-09-2012, 10:17 PM | #1 |
Newbie Join Date: Jan 2012 Location: in the rocks
| esc question
I was driving my creeper and it rolled and hit the top of the body on a rock and knocked the black wire loose. No eletronics got hit, just the black wire got loose. Its got a castle sv2 with a venom 55t motor on it. Ive checked everything and no luck. What to do |
03-09-2012, 11:32 PM | #2 |
| Re: esc question
What do you mean that the black wire got loose? From the ESC itself or from the bullet on the end or from the wire coming from the motor?
03-10-2012, 03:23 AM | #3 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: esc question
I think he does not know where it was connected or soldered to
03-10-2012, 04:11 AM | #4 |
Pebble Pounder Join Date: Apr 2011 Location: Liverpool Y.N.W.A.
| Re: esc question
Any chance of some pic's It should make it easier for us to understand your problem. |
03-10-2012, 06:21 AM | #5 | |
| Re: esc question Quote:
From the bullet on the end (just came unplugged). Ive hooked it up on castle.com and checked everything and no luck there. When I cut the esc on the green light blinks real fast and stearing works fine. Ive even tried recalibrating the esc, nothing....... | |
03-10-2012, 07:18 AM | #6 |
Did you try plugging the bullet connector back in?
03-10-2012, 01:41 PM | #7 |
| Re: esc question |
03-10-2012, 02:17 PM | #8 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: esc question
Whoa, easy there. You didn't really give a lot of information in your opening post. Like which wire...there's a few "black" ones. Also, no indication what exactly wasn't working. Providing more info will result in more informed responses... ...and save some tempers. |
03-10-2012, 02:29 PM | #9 |
| Re: esc question |
03-10-2012, 02:40 PM | #10 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
Post a pic.
03-10-2012, 02:58 PM | #11 |
| Re: esc question Its the black wire coming from the motor and I plugged it back up. Posting a pic isn't gona do no good because there's nothing wrong its the escape. I cut the escape on and the green light blinks fast.
03-10-2012, 03:01 PM | #12 |
Rock Stacker Join Date: Feb 2012 Location: Enfield CT.
| Re: esc question
He's just mad because he hasn't figured out how to figure things out. Hey OP does this help?... |
03-10-2012, 03:08 PM | #13 | |
1-What is an "escape"?? I'm assuming you have an "auto correct" and it's messing with you. 2-RTFM (sorta like, read the manual).... link.... Castle Creations | FAQ: 1/10th Scale Products , sounds like the LVC is killing the ESC (or, is that "escape"??) Now, do you want help, or not?? | |
03-10-2012, 03:27 PM | #14 |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
| Re: esc question |
03-10-2012, 05:07 PM | #15 | |
Sorry for all the confusion again... | |
03-10-2012, 05:18 PM | #16 |
| Re: esc question |
03-10-2012, 05:27 PM | #17 | |
I know its probably something simple but I can't pin point it. What do you think the green light would be flashing fast for when I cut the esc on? | |
03-10-2012, 05:59 PM | #18 |
RCC Addict Join Date: Oct 2007 Location: gervais
You should still provide pics, make it alot easier because the way your saying it is kinda hard to understand. Plus A temper to people trying to help you won't get you far here
03-10-2012, 06:31 PM | #19 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
first off you need to understand were not getting paid to answer your questions so don't give us any lip. The best way to get help is to provide us with as much info as possible. Pics and video are awesome.its like calling a computer help desk and saying my computers broken, ok sir what's wrong with it? I don't know its just broke, fix it Mr computer man! With that being said, sounds like you just lost your programming. the green light flashing means you just lost your signal. You need to reprogram your esc, you don't even have to change anything just plug it up on your pc and reload the settings. I'm going to assume your using a sensored setup, this happens mostly on my sensored setups although I have had it happen to non sensored ones. So again, I would reprogram via pc, rebind TX to rx then reprogram TX to esc and you should be golden. let us know. LIK |
03-10-2012, 08:20 PM | #20 | |
Thanks iv tried reprograming the esc but it wont reprogram. Im using the castle link cable. Reprogramed/pluged up to pc and still blinking green light. Man this thing is about to get the best of me. lol Ive been fooling with it on and off allday. The stearing works fine but no foward or backwards. Just wish I could get it going..... Thanks again.... Im not gona take my out on here no more... Just had a bad day I guess. Sorry again... | |
esc question - Similar Threads | ||||
esc question | skull kandy | Newbie General | 2 | 05-31-2010 09:58 AM |
Esc question | boisetrucker | Duratrax Cliff Climber | 2 | 01-12-2010 10:38 AM |
New ESC question | Cougar | Newbie General | 8 | 12-07-2009 09:30 PM |
Another ESC question | h8z2luze | Losi Mini-Rock Crawler | 6 | 09-20-2009 10:38 PM |
esc question? | wixjp | Newbie General | 6 | 08-10-2009 04:00 PM |
