Thread: Quick help! Hitec servo 5995tg
Old 04-01-2012, 12:58 PM   #1
Default Quick help! Hitec servo 5995tg
I will be using a Futaba 4pl radio. Can this radio handle this hitec servo 5995tg robot servo 180 degree rotation? Something about epa adjustments needed. They are $50 off right now.
juswin24 is offline   Reply With Quote
Old 04-01-2012, 12:59 PM   #2
Default Re: Quick help! Hitec servo 5995tg
Oh, it is going in my scx dingo.
Old 04-01-2012, 12:59 PM   #3
666
MODERHATER™
666's Avatar
Yes it can, you will need to adjust accordingly though.
Please do tell where they are 50% off!
666 is offline   Reply With Quote
Old 04-01-2012, 01:24 PM   #4
They are $50.00 off $119.00 at Servocity.
Old 04-01-2012, 02:01 PM   #5
Usually it's NOT the radio, you may need the HiTec programmer to gain more servo travel.
You can lengthen the servo movement (longer arm/horn) or shorten the knuckle mount (may get closer to "0" ackerman).
Neither of these need to reprogram the servo.
I "believe" that you need a "79xx" servo to use the HiTec programmer for servo throw.
Charlie-III is offline   Reply With Quote
Old 04-01-2012, 02:23 PM   #6
Grab them fast!! I ordered one, and posted on the SCRC Forum about the deal, and those guys are grabbing them as well. I use a 5990 in my 1.9 Losi and love it....Could not pass up one of the 5995's.
xirtic is offline   Reply With Quote
Old 04-01-2012, 04:38 PM   #7
Originally Posted by xirtic View Post
Grab them fast!! I ordered one, and posted on the SCRC Forum about the deal, and those guys are grabbing them as well. I use a 5990 in my 1.9 Losi and love it....Could not pass up one of the 5955's.
Just so you know it's 5995tg not 5955 servo.
Old 04-01-2012, 04:40 PM   #8
I was more concern about to much steering not enough. I just want to be able to get a good deal on a high torque servo that I could use. I did order one.
Old 04-01-2012, 05:02 PM   #9
Nobody
Cordwood's Avatar
Thought I'd share
Cordwood is offline   Reply With Quote
Old 04-01-2012, 05:04 PM   #10
typo on my part....I also own 5955s
Old 04-01-2012, 05:25 PM   #11
Most decent radios have EPA's on the steering channel, thus yes, you can dial the servo swing back some.
Old 04-01-2012, 07:35 PM   #12
Official Cook of the ECC
Scattman's Avatar
Not correct.....The 59xx are 180 degree adjustable with the programmer as well.
Scattman is offline   Reply With Quote
Quick help! Hitec servo 5995tg - Similar Threads
Hitec 5995tg and CC Bec jeepster73 Electronics 5 06-16-2009 02:22 PM
Hitec 5995tg Robot Servo Fix - Help save your robot servo from overheating kevinlongisland Electronics 56 03-11-2009 03:48 PM
Hitec HS-5995TG and HS-5955TG which one? 5zigendes Electronics 5 09-04-2006 07:12 PM
Hitec 5995TG wacked out cheapjeep2 Electronics 3 01-25-2005 10:39 AM
