4 pl with dual esc programming issues!!! Here is the basic rundown. I've got 3 crawler roosters. I watched the videos Harley has for programming the 4 pl. did programmed it it's close but no go. My main issue is when I turn on the speed controllers the rear motor just starts running in reverse like half throttle. I give it throttle and at 1/4 throttle front is going forward and rear is going reverse. 1/2 throttle front is going faster and rear is now going forward slowly. Full throttle they they are both going full speed forward. Let off the throttle and rear stops then starts going reverse again. If I move the subtrim all the way forward and move the regular trim to about 38 it will stop going reverse. Then if I throttle car forward the front starts going and the rear doesn't start moving till I am about 1/2 throttle. I'm so frustrated. |
2 rooster crawlers not 3. Lol |
Re: 4 pl with dual esc programming issues!!! You might want to give us a little more setup info. Did you set the epa's at 0 when calibrating, etc... |
Re: 4 pl with dual esc programming issues!!! Quote:
1-Were the throttle trims to "0" 2-Throttle EPA's to "100%" 3-Throttle subtrims to "0" Calibrate both ESC's to the RX. |
Re: 4 pl with dual esc programming issues!!! Yea you need to calibrate. |
Everything set to zero trims and subtrims. EPA set. Everything set to zero rear motor is going atleast 1/2 to 3/4 speed in reverse. Front isn't moving. |
How do I calibrate speed controls. I bought this radio off eBay it was in box but no instruction. Maybe I'll go to hobby shop tommorow and see about a manual. |
Re: 4 pl with dual esc programming issues!!! Just download the manual from Futaba. Also download the Rooster manual from Novak. |
Re: 4 pl with dual esc programming issues!!! What you need is the manual for the ESC's not the radio. Calibration is a procedure to let the ESC know what signals it will receive for Forward, Reverse, and Neutral. To verify the radio programming you could always go into the monitor screen and verify that the two throttle channels are indeed the same when set for full power. |
Thanks again everybody the rear speed control actually turned out to be bad. Bought another one off the classifieds calibrated and bam good to go. No matter how much I calibrated or tried it just would work with me. LOL |
