Motor turns??? How to know how much turns have a motor if I have not any specifications of it??? How to know how much RPM is it??? I’m considering to use a motor out off a cordless drill, a Power Tools, just as an experiment and the only I know about this motor it runs with a 12V battery and is Johnson brand. Could I use a brushed ESC to control it??? I have a stock LNC ESC and a HH BR-XL ESC, could I use any of them to run that motor without problems??? Any comment and suggestions welcome Thanks guys El Vasco"thumbsup" |
Re: Motor turns??? Get a model number off the motor iff possible, then Google it. You could always open it up and count. If I had to guess, I'd say it has high number of turns, because drills tend to require high torque. |
Re: Motor turns??? Even with RC motors, there is no good way to tell the turn count without pulling the wire off. Even if the motor had a part number on it, it would be tough to get specifics on turns or RPM/volt speed. If it's a brushed motor (likely) then there are lots of ESC's that can likely handle it. Try it but check ESC & motor temps. |
Re: Motor turns??? Quote:
Hey Charlie!!! How are you man!!! Do you remember me??? Time ago you were helping me with motor and esc issues and now I got another question you are here again, thanks man!!!"thumbsup" You know you method will be the most correct but I don’t want to pull all the wire off to know the T’s of my motor, I'd have no more motor then:lmao: I think I’ll go with your second suggestion, I’ll connect the motor to one of my esc’s and will test it controlling esc and motor temp :roll::shock::mrgreen: When I get my test done I’ll come back here just to let you know how it was going. See you and thanks for helping me in this one too!!! El Vasco!!!"thumbsup" |
Re: Motor turns??? Yes, I remember you.8) |
