novak mongoose esc getting hot i have a mongoose 18.5 using 2s lipo. i ordered a nano-tech 470mAh 3s and pluged in and it started to heat up:shock:. from the novak site it says its 3s compatable. i only did one quick trigger pull and was supprised at the speed difference but heat id too much. do i need to set it up for 3s through the programing, would this cause the problem. Built-in 2S & 3S Li-Po Cut-off Circuitry (can be activated in any of the throttle profile Input Voltage: 2-3 Li-Poly cells or 4-9 Ni-MH/Ni-Cd cells (1.2V/cell) thanks for the help"thumbsup" |
Re: novak mongoose esc getting hot IIRC, you dont have to change anything on the ESC to run a 3S. At least mine never did.....but then, it did end it's life in a big ball of flames. :lol: Here's the programming instructions: http://www.teamnovak.com/products/br...gprogsheet.pdf |
Re: novak mongoose esc getting hot OK, I did all the programing an checked an double checked an triple checked.. programmed everything I could an I still can't get the darn esc to let me switch it to 3s.. blinks once an blinks twice for 2s, it will not blink for 3s.. what's the deal with this thing! Any tricks? Am I missing something? Also, the esc got hot or warm, just, during setup.. normal? |
Not sure if it's normal or not but that didn't happen to me also one blink or two blink for Lipo cut off cannot get into 3s cut off and yes it did get warm |
Re: novak mongoose esc getting hot So be it I guess... I had some 2s so ran them.. works good but not like 3s... no jumping gaps now. :( |
Re: novak mongoose esc getting hot Quote:
Re: novak mongoose esc getting hot Lmfao! Well all soldered joints are factory.. gear mesh is perfect.. 2s batteries are over 30c, 3s are 25c or over.. only thing I'm missing is the trash can! Tho I feel that way bout the CC stuff I have had.. 3 esc an 4bec between a fellow crawler an myself.. |
Re: novak mongoose esc getting hot Old thread revival, but it's right on topic. I've had my Novak Mongoose system for about 2 years and I use 60C or higher 2S and 3S batteries with my Losi MRC. I have the Novak fan on the ESC, given I was getting thermal shutdown occasionally on 2S and frequently on 3S. Fan makes little difference, it just means I get another 10 seconds on 3S before it shuts off. Very frustrating! For anyone reading this thread in future with the same problem, here's what I'm going to do about it: 1. forget about the water proofing feature of the ESC, I don't need it. 1b. open the ESC and remove the tiny little heatsink 2. install a bigger heatsink and fan, including a little amount of quality thermal transfer compound. 3. test and report back. Watch this space. (If all else fails, I'll use The Violator's method. Made in America doesn't seem to do the trick in this instance - my Chinese motors and ESCs have been flawless. Bleh!) |
I plugged a 2s into my Novak Three80 18.5T setup the other day ( same battery I have always been using ) and after about 30 secs the motor got real hot and started smoking! |
