Thread: Anyone used Novak 13.5 sensored
Old 08-19-2012, 02:57 PM   #1
Default Anyone used Novak 13.5 sensored
I'm looking at getting a new/used motor for my lcc. I found one on eBay used(seller says very used) it is a race spec motor 3300 KV sensored. It does still work
EricTheRitt is offline   Reply With Quote
Old 08-19-2012, 04:30 PM   #2
Default Re: Anyone used Novak 13.5 sensored
I run a 13.5ss sensored brushless on my scx10. I dont know how it will do with the worm drive axles. Runs great on my rig!
jessejoe23 is offline   Reply With Quote
Old 08-19-2012, 06:24 PM   #3
I run one in my Wroncho with a MMP and 3S. Works great. Just picked up a 17.5t for my AX as well.
rmb2485 is offline   Reply With Quote
Old 08-19-2012, 11:57 PM   #4
You could replace the standard (12.3mm) rotor with the larger crawler rotor (14mm, #5950) to reduce the speed and increase torque.
Then it should be a great motor for the LCC.
Olle P is offline   Reply With Quote
Old 08-20-2012, 05:07 PM   #5
That motor will work fine in a losi, many people have started using the 13.5t motor in them. But don't put the 14mm rotor in it, it will not run very smooth with it
benoj is offline   Reply With Quote
Anyone used Novak 13.5 sensored - Similar Threads
novak three-80 sensored josh6575 Electronics 0 02-13-2012 06:55 AM
novak goat 2s problem sensored DkoD General Crawlers 4 10-11-2011 01:55 PM
13.5 Novak Sensored Brushless....Any suggestions? matthewjbear Team Losi Comp Crawler 32 06-26-2009 05:58 PM
