gt3c hacked with outcry dual esc i am trying to figure out how to program my gt3c for my bully moa. i was told that i can use this remote to control the front and rear axles separately. anyone know if this is possible or how to make it work? |
Re: gt3c hacked with outcry dual esc that feature is for dual esc's or a 3pos switch for a dig switch. that esc cant be used to control each motor separate. it has one motor output with 2 wires to simplify motor hook up |
Re: gt3c hacked with outcry dual esc what do you recommend to set this up to work? a different esc? or can i add dig unit? thanks for the help |
Re: gt3c hacked with outcry dual esc you can run a dig with a 3pos 3rd channel and one esc. or set the radio to mix 2 esc's. theres a hack thread for that radio. my gt3b is not hacked so i have no clue how to set esc mixing. the outcry will work with a dig.a punk gig has one input and 2 outputs.just use one set of motor leads to the dig,(clip off,or de solder for the board the other set of motor leads) and each motor to the dig |
Re: gt3c hacked with outcry dual esc Quote:
This dig controller will work on an unmodified GT3B with a stock two position third channel and you get both front and rear dig. MOA Dig Controller for Two Position Channel Or if you have three positions: MOA Dig Controller for Three Position Channel |
Re: gt3c hacked with outcry dual esc thanks stanmodz and heyok! i will have to get a dig switch. glad i asked. i have been trying to program my outcry to no avail. thanks again |
