Thread: How many volts should display? Life battery
Old 02-19-2013, 05:09 PM   #1
Default How many volts should display? Life battery
On a life battery, 2 cell, on full charge in a 4PK transmitter, how many volts should it display? Mine currently says 6.9 V. My battery charger Throwing back full messages and connection break errors. I'm trying to figure out if the pack is fully charged or not. Can I charge the LIFe battery in the 4PK transmitter by plugging in the standard for futaba charger into the transmitter?
Mysterious is offline   Reply With Quote
Old 02-19-2013, 06:25 PM   #2
Default Re: How many volts should display? Life battery
My guess is your transmitter charger is programed for NiMH batteries. Charge the LiFe on your LiFe compatible charger and then put it into your Tx. The voltage will read correctly thru the TX so you will be good to go.
DudeWalker is offline   Reply With Quote
How many volts should display? Life battery - Similar Threads
Battery Life jmike Team Losi Comp Crawler 9 12-02-2010 12:49 PM
Better battery life Slade Axial SCX-10 18 10-07-2010 01:05 PM
battery life??? o3_xterra Newbie General 3 11-03-2009 09:15 PM
battery volts.............. bob1961 Electronics 4 04-26-2009 10:15 AM
Using 1 battery to get 14.4 volts S-Dog Electronics 8 01-03-2007 09:53 AM
