02-10-2013, 09:12 AM | #1 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| FXR vs Sidewinder micro in xr10 differences?
So I recently made the change from fxr's to the micro sidewinder and was wondering if anyone else noticed a power loss? I don't have as much torque or wheel speed and can actually stall the motor in a bind. I never could stall a motor with fxrs before. Is this normal? Upside is I have a much better drag brake and smoother start up. Should I look into more powerful motors to fix the torque/wheelspeed issue? Let me know what you gus think... |
02-10-2013, 10:23 AM | #2 |
| Re: FXR vs Sidewinder micro in xr10 differences?
I've run both in my XR-10 with decent 35T motors on 3S (dual ESC's in both cases). I can't say I saw a power difference between the 2 ESC's, but I did notice some of what you saw. Smoother start-up with the SM's and better drag brake. I would double check your ESC to motor & ESC to battery connections and make sure you don't have a cold joint. |
02-11-2013, 10:38 AM | #3 |
I have checked all joints and there good!!! The best way to discribe it is like I went down in volts. I can actually stall out a motor in a bind now where as I could never do that before with the fxr's. The only difference between the 2 setups that I have done is use a different make wire but same gauge. I beleive the wire I am using with sm is better then the wire I used for the fxrs. I have another guy in my club that did the switch as well and he is reporting the same thing. |
FXR vs Sidewinder micro in xr10 differences? - Similar Threads | ||||
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? | username | Electronics | 3 | 04-04-2009 10:11 PM |
