DX3R Set Up Issue hello, hope someone can give me a suggestion, I have just installed the drivetrain and receiver to my honcho. I am using the goat crawler 3S system and a spektrum sr3100 receiver. When I bind the receiver it says to leave the controller in the failsafe neutral position. which I would assume is steering in the middle and no throttle. It binds fine and is connecting. Steering is in the middle but throttle seams to be at about 15-20% when the trigger is in the middle / neutral position. I have to apply reverse to get the rig to stop. Did I bind this wrong or what do I need to do to get the throttle to be stopped when no pressure is applied to the trigger in forward or reverse. thanks in advance. P |
Re: DX3R Set Up Issue Sounds like a throttle trim issue |
