Thread: servo chatter
Old 03-24-2013, 04:31 PM   #1
Default servo chatter
so i put in a new hs7954sh in my wraith.it works fine but it sort of chatters as it sits still.just makes noise.a little flick of the wheel on the tx usually makes it mostly stop.is this normal?
i have a MMP/tekin 13.5 set up with 2s
stock rtr tx/rx ax3
and yes,i have a bec
seaturtle is offline   Reply With Quote
Old 03-24-2013, 04:34 PM   #2
Norton's Avatar
Default Re: servo chatter
Is it a digital servo? My Savox makes noise but doesn't effect it.
Norton is offline   Reply With Quote
Old 03-24-2013, 04:43 PM   #3
Sounds like normal digital servo chatter to me.
Older analogs were/are a lot quieter. If you turn your wheels or pick the truck up and set it back down and it stops that's normal.
Sent from my iPhone using autocorrect
happymachinist is offline   Reply With Quote
Old 03-24-2013, 05:21 PM   #4
I cant hear the servos from the other guys I run with over my Savox..moves rocks, doesn't effect the reaction of the servo.
squatch71 is offline   Reply With Quote
Old 03-24-2013, 05:42 PM   #5
It's normal, digital servos are always trying to find "0", if you lift up the steering end, the sound usually goes away (regardless of brand).
A little "twitch" of the steering can also make the sound go away.
The servo is "hunting", not an issue.
Charlie-III is offline   Reply With Quote
Old 03-24-2013, 05:42 PM   #6
Word!
Old 05-04-2013, 06:53 PM   #7
Exactly what I needed to read. Search function rules lol! I just quickly tested my new savox and BEC before we started watching a movie And my ADHD wouldn't let me relax without knowing the sound is normal.
BAWLER CRAWLER is offline   Reply With Quote
servo chatter - Similar Threads
Delaware chatter 02tac Delaware 526 03-14-2017 09:48 AM
drive line chatter steveo 561 Axial SCX-10 7 11-02-2014 07:32 AM
RC4wd winch + TQ4. chatter frizzen Electronics 9 07-02-2012 10:10 PM
Rear axle chatter? traxxas4fun Axial SCX-10 21 01-03-2011 02:30 PM
Axial Scale Parts...I'm surprised there's so little chatter... goldmember Axial SCX-10 6 07-24-2009 03:05 PM
