Brand new scx10 goes into reverse and full throttle rev when radio off? Just got a brand new rubicon I take It to the trail and occasionally it goes in reverse full throttle on its own, also when I turn off remote it goes full throttle as well, any ideas? Is there even a failsafe I can set so when the remote is turned off the truck don't take off on me? |
Plus its not a good idea to keep your rig on and your transmitter off...glitching can occur Replace your transmitter batteries! |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? Ya, it could be anything sending it a signal if your radio is off. |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? Quote:
Oh i know this, but its odd this happens to this rig, i have 3 other scx10's and they do not fly away when i turn the tx off. |
I see this posted a lot, the fact remains you should never do this. If you never do this then it will not be a problem. Sent from my RM-845_nam_vzw_100 using Board Express |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? To begin with check all of your electrical connections for loose or exposed wiring, make sure your aerial is not attached to any metal parts of the chassis and try resetting your esc.. What type of radio are you using, am/fm or 2.4ghz. What electronics are using, cheap crap or quality? |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? its all stock from a brand new Axial scx10 Jeep Rubicon RTR .... Axial AX-3 TX & RX.... AE-2 ESC Im thinking the RX is defective. |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? [QUOTE=milestone;4340657] Im thinking the RX is defective I believe you have this backward...your thinking is defective |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? [QUOTE=Postclanker;4340680] Quote:
Yeah, seriously, if your cables are all routed correctly and neatly and this still occurs then DON'T DO IT! ;-) |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? While it's been established you shouldn't turn off the TX with the rig on, here are some thoughts. 1-ESC not well set-up, thus it moves, recalibrate it. 2-Most RX's have a "fail-safe" mode you can set. You either want "full brake" (Nitro rigs with no reverse) or "neutral" (rigs that have reverse). It really does not matter what the radio is (AM, FM or 2.4ghz), no signal/poor signal to the RX can yield odd results. |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? with everything set to center rebind the tx to the rx this will set the fail safe to center and it wont do it again |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? Hey guys found out it was just interference with my Radio and my friends, we had to change out radio/ receiver and all is good now... Truck still takes off when radio turned off but thats fine, i hear its normal with certain models. Thanks for all your input! |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? If it happens again try and reset the fail safe on your receiver. As follows, http://docs.axialracing.com/instruct...structions.pdf On the bottom left of page. The truck should not move when it loses signal withe transmitter. |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? Once again rx off tx off. Tx on rx on. |
Re: Brand new scx10 goes into reverse and full throttle rev when radio off? |
