2 motors 1 esc? So I know Novak has an esc that can power two motors but can a tekin for do the same? Or any other esc that can do it? I will be using a cc bec to power the servos directly to take the load off the esc Sent from my VS930 4G using Tapatalk 2 |
Any esc can, as long as you don't go over the motor turn limit of the esc. |
Thanks for the info Sent from my VS930 4G using Tapatalk 2 |
Re: 2 motors 1 esc? What Novak?? I would NOT recommend the M2 dig. Sounds good on paper, not so good in application (from what I tried/observed). As to "turn limits", if it states "35T minimum", then you are likely stuck with 2 ~70T motors to stay close to what the ESC can handle on a single ESC. Are you running a MOA or 2 motors on a single motor plate on a trans? For a MOA, a servo dig & single ESC is "workable", dual ESC's and a radio that can do mixing is best. I have used both. |
Ya I'm not too fond of Novak. Its for a moa and I do have a hacked gt3b that ice used for a xr10 before with dig and 4ws but I'm trying to keep cost down. I've used fxrs and I really like em so I just wanted to get one but I know two would be the best way to go Sent from my VS930 4G using Tapatalk 2 |
X2 on the Novak.. Just stay away from the m2 and save the headaches and stress! |
