bec wiring I know this thread is beatin to death! I just got a savox 1230. 500 oz. I have a castle bec. Holmes brxl esc. I searched and searched and cant find a solid answer.. does anyone have a easy wiring diagram. Im ready to pull my hait out! Help please . Thanks for any help. |
Are u just trying to wire the servo to the bec? Or run everything off the bec? Sent from under the sheets |
Re: bec wiring |
Re: bec wiring I m just upgrading to a better servo and realize i need a bec. Not sure exactly what it is they do. Just know in eed one. Just wondering the best waybto go about it. |
I just put the castle creations bec on my night crawler. It was very strait forward, I just followed the diagram on the package... programmed it then soldered in thr power wires, plugged it in after disconnecting the red wire from the esc harness... http://img.tapatalk.com/d/13/09/29/ygagysa6.jpg Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
Re: bec wiring 1 Attachment(s) Here is an easy diagram for SERVO hookup. . |
Re: bec wiring Quote:
Fixed the diagram! :oops: I run the ground from the servo to rx as well, just forgot to update my pic. "thumbsup" I usually make a Y harness to go between the three so I don't lose the plugs for programing purposes. . |
That was quick! "thumbsup" Good stuff, that diagram is pretty much how those with hv servos do work. Saw a rig go off a small cliff because of it, so it's stained on the brain. Edit: same here on the y's, picked up a bundle of male and female pigtails to make them at will. |
Re: bec wiring 1 Attachment(s) Quote:
Not sure of a specific thread... Here is a photo of one. The plug with just black and white wire go to the rx The plug with just red and black go to the BEC The plug with all three/four wires goes to servo You can make it as big as you want or as small as you want, but that is the basic set up. . |
Also iirc there are a couple vendors that make "rx bypass" adaptors, for those that are shy about the diy method. |
Re: bec wiring so here is my question... I did run with bypass wire for all my scale rigs...but I don't know why we need the black wire to go to RX. can anyone tell me some info??? |
Re: BEC wiring Quote:
While the extra ground WILL NOT HURT ANYTHING, it can sometimes help with "glitches". In general, having a common ground point (usually the RX) is best, some set-ups can skate by without it. I have NOT had radio issues with either my Futaba 3PM-x or hacked GT3B (running the external BEC direct to the servo without the servo/RX ground), but that does not mean the extra ground wouldn't help.8) |
