09-30-2006, 09:25 PM | #1 |
| DX-6 help!!
Hey i just got a DX-6 and it's giving me fits! Everytime i stop and let it sit for a few it shuts down, i shut off the radio and turn it back on and it works for a while and shuts down again! Info: 2 Tekin Rebel 2's, 2 5955 servos, 6 cell 3800 pack for the TR2's, and a 2700 receiver pack. Any suggestions? Thanks! |
09-30-2006, 11:21 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Define "it". Are you losing TX power or is the truck itself going dead? I've never experienced this problem, and I routinely let my trucks sit while bullchittin'. |
09-30-2006, 11:48 PM | #3 |
The truck dies, servos still buzz but no response? I watched it roll down a cliff because of this! |
09-30-2006, 11:50 PM | #4 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Better get it fixed, we're wheelin in 8 hours!!!
09-30-2006, 11:54 PM | #5 |
HA HA Along w/ the broken axle tubes and getting the Hi-Lift done too!
09-30-2006, 11:59 PM | #6 |
damn gonna pull an all nighter?
10-01-2006, 12:10 AM | #7 |
Looks like it! Need Red Bull......
10-01-2006, 12:59 AM | #8 |
stumps me! I have never had such an event occur. So when you "reboot" the TX it works again for a bit?
10-01-2006, 07:52 AM | #9 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
| this is what i did
i dunno if this is what your problem is but this was mine, first off change those crappy batteries, i used duracell 2650 aa's i soldered 8 cells together, then added another pigtail power plug. i think airplanes and helis only run for short periods of time (throttle always on). 700mah batteries just dont cut it when your trailin, maybe for comps though. next i re-binded the receiver at zero throttle in case battery in tx dies it doesn't think it's a plane and goes flying off a cliff(fail safe is set from the factory to run motor-in case of tx power down). good luck
10-02-2006, 01:37 PM | #10 |
I joined the Band! Join Date: Aug 2005 Location: Cincinnati
try disabling the failsafe, it may be that you are getting a touch of interference and the failsafe is kicking out until it is the clearest signal. sounds like throttle is cutting out but the steering is in tact.
10-02-2006, 07:58 PM | #11 |
It stops the steering and the throttles, but u can hear the servos buzzing like they have power. I turn the radio off and then back on and it works... for a while. How do i disable the failsafe? |
10-02-2006, 09:49 PM | #12 |
Wait...are you switching the TR2s on?
10-02-2006, 09:53 PM | #13 |
Yes, both are on!
10-02-2006, 10:02 PM | #14 |
Turn'm off and try again. You're using a RX pack...no need to use the BEC circuits on both TR2s. Or, ditch the rx pack and turn on only ONE TR2. |
10-03-2006, 09:11 AM | #15 |
You think its overloading the circuit JIA?
10-16-2006, 07:57 PM | #16 |
Fixed it w/ Spectrum part # SPM 1600, Voltage Protector. It was a voltage drop issue! |
10-17-2006, 07:26 AM | #17 | |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
