10-21-2013, 08:56 PM | #1 |
Newbie Join Date: Sep 2013 Location: WDM
| AE-2 ESC no forward/reverse or red led
I have an SCX10 RTR that i got back in september. I was running it the other day and it ran great, got done and put it away. I went to run it tonight and I have no throttle. The steering works, but no throttle. The motor works (hooked it direct to my battery) but no throttle. When I turn it on, i get the start up beeps with the red and green light on but then the red light goes out and the green light just strobes. I tried to recalibrate it but it won't even do that. When i move the throttle there is nothing going on on the ESC. I have adjusted the throttle 'zero' on the AX-3 so may times I had to hit neutral at one point but still no go. Any ideas on what to do next? I dont have any spares or places to test the esc so that is out of the question. Bummed cause I wanted to do a little crawlin tonight. CyBuzz |
10-21-2013, 09:02 PM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: AE-2 ESC no forward/reverse or red led
Plug the esc into the steering channel on the receiver and turn the steering wheel to see if it works. I had the same thing going on and it turned out being a throttle trim adjustment on the TX that had gotten bumped.
10-21-2013, 09:05 PM | #3 | |
| Re: AE-2 ESC no forward/reverse or red led Quote:
THanks for the input though...didnt think to test that way. | |
10-21-2013, 09:29 PM | #4 |
well, that was fun....now it just works. now i am going to see if i can mess it up again.
10-21-2013, 09:30 PM | #5 |
Based on this..... Castle Creations | FAQ: 1/10th Scale Products Do the following.... Throttle trim (and sub trims) to "0" Throttle EPA's to 100% (both directions) Try it out and then get back to us. |
10-21-2013, 09:51 PM | #6 |
could this have been my lipo cutoff? i think i tried a couple different batteries...but...it is late... time to balance/charge battery Y
10-22-2013, 06:32 AM | #7 | |
Also make sure your TX batteries are good. | |
AE-2 ESC no forward/reverse or red led - Similar Threads | ||||
Castle esc forward to reverse question | day215 | Electronics | 4 | 12-26-2010 01:54 PM |
Axial AE-1 Forward/Reverse ESC | JBennett | Electronics | 6 | 04-18-2009 09:07 AM |
