08-07-2014, 06:39 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| 4 pole vs. 2 Pole motors
I am new to brushless motors. I understand that for crawling I must use a sensored motor. I have a Mamba Max Pro driving a brushed motor. So what are the advantages of a 4 pole versus 2 pole motor? |
08-07-2014, 07:01 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: 4 pole vs. 2 Pole motors
4 pole has more torque and has a smoother bottom end. 2 pole are good for high rpm applications (onroads, planes, boats, 2wd buggies)
08-07-2014, 07:12 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: 4 pole vs. 2 Pole motors |
08-07-2014, 08:38 PM | #4 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Twice the poles.
08-07-2014, 09:33 PM | #5 |
| Re: 4 pole vs. 2 Pole motors Not always. If you want something that starts up like a brushed motor, then yes, sensored is your best bet. If smooth startup is not uber important, then you can work with non sensored but you will have to pick your esc a bit more carefully.
Tags |
2 pole, 4 pole, brushless |
4 pole vs. 2 Pole motors - Similar Threads | ||||
need advise, sensorless 550 2-pole 3300kv or sensored 540 4-pole 3300kv | Steelfish | Electronics | 20 | 06-21-2013 10:20 PM |
tekin redline gen2 2 pole or 4 pole | gofaster427 | Electronics | 2 | 02-24-2013 05:22 PM |
4 pole motors. | corkysk8 | Electronics | 1 | 08-13-2011 09:13 PM |
5 pole motors | chafey | Electronics | 4 | 06-26-2006 09:45 AM |
