02-20-2015, 09:25 PM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: Arvada
| Mamba Max Pro dead?
I was running my wraith in about 15 minute intervals today while I tweaked the suspension a bit. It is set up with the MMP, Hitec 7954 with BEC, Tekin 13.5t sensored brushless motor, metal trans gears, MIP driveshafts, HD gears, HR spools, etc. Motor temps never reached more than 105. The last interval I was driving it around my house and hit lipo cut. So I charge the battery and put it back in after it was fully charged. The MMP won't do anything at all. I plugged it in to my castle link and get nothing there as well. There was never any smoke or sparks or signs of failure. Just lipo cut and then it never came back. The castle link does not change light colors or act like anything is connected. Sounds like the 2 week old MMP is toast to me. Ideas?
02-20-2015, 10:00 PM | #2 |
Pebble Pounder Join Date: Dec 2014 Location: Ontario Canada
| Re: Mamba Max Pro dead?
is your on/off switch possibly broken? Thats common for castle ESC's.
02-20-2015, 11:21 PM | #3 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Did the bec run the rx or just the servo? If just the servo try running the rx with bec.
02-21-2015, 06:10 AM | #4 |
| Re: Mamba Max Pro dead? |
02-21-2015, 06:11 AM | #5 |
02-21-2015, 06:59 AM | #6 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
I wonder if it has a loose battery connector or a bad solder on one of the MMP power wires and you didn't hit LVC but it was a bad connection causing intermittent power going to the MMP?
02-21-2015, 07:14 AM | #7 |
Did you remove the red power wire from the receiver when powering the receiver with your external bec? Do any of the LEDs on the MMPro light up when powered on? Mine did the "blinking red light of death" when it croaked. Hopefully you didn't waterproof it and can get Castle to warranty it. |
02-21-2015, 07:31 AM | #8 |
02-21-2015, 07:37 AM | #9 | |
Pebble Pounder Join Date: Apr 2013 Location: traverse
| Re: Mamba Max Pro dead? Quote:
I too was wondering if you forgot to unplug the red esc wire when installing the bec? | |
02-21-2015, 08:10 AM | #10 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Does anything light up when you plug in a batt? If not. Try using a different BEC/receiver pack. |
02-21-2015, 09:10 AM | #11 | |||
No lights from the MMP at all when connected to a fully charged battery or when connected to the castle link. All of my lights, rx and servo work fine from the BEC power. Last edited by 73bronco; 02-21-2015 at 09:13 AM. | |||
02-21-2015, 10:26 AM | #12 |
Counting this one as a fluke failure. My hobby shop is awesome and is taking care of me as expected. I'll have a new MMP next week.
02-21-2015, 07:39 PM | #13 |
Rock Crawler Join Date: Feb 2011 Location: Williston
glad to hear it, I wish all hobby shops were that good! L.R. |
Mamba Max Pro dead? - Similar Threads | ||||
Mamba Max Pro and Mamba Max Pro Short Course? | Soulo747 | Electronics | 5 | 01-31-2013 10:04 PM |
Mamba Max Pro - vs - Mamba Max Pro SCT | rctoyguy | Electronics | 1 | 06-08-2012 06:19 PM |
