06-08-2017, 01:32 AM | #1 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Puller Pro 2200kv
Dear all, Just receiving my HH PP BL 540 2200kv water proof brushless motor today and noticed in front of the motor can there are 6 holes there. My first HH PP 3500kv water proof brushless motor sold to one of my friend and I could not remember, were there normal if there are 6 open holes in front the motor can? Am I receiving the correct motor? As I am just wondering if there are holes, how can it called water proof? Please pardon my silly questions here. |
06-08-2017, 01:41 AM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Puller Pro 2200kv
Water doesn't affect the armature but rather the sensor board (that's why all brushed motors are waterproof). Holmes coats the sensor board and all connectors to make these waterproof.
06-08-2017, 02:24 AM | #3 |
Thank you mikebecher for your input here( Appreciated ) Since the water can go inside the motor can mean including tiny stones and debris. If I remember correctly in the video Harley used to teach us, how he used a silicone glued to seal up all the holes on the Tekin ROC412 motor. https://www.youtube.com/watch?v=Df_Y...uryAbx6w9UZQWZ Do you think it is good to seal it up with silicone glue? Also how often one needs to take apart the motor for a general service, like re-lube the seal bearings and give it a good clean? Thank you |
06-08-2017, 05:55 AM | #4 |
Those holes on the endbell are going to be pressed against the motor plate so not much is going to get in there. If you still feel the need to close them up, use some M3 setscrews instead of glue.
06-08-2017, 09:54 AM | #5 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
Make sure if your going for a dip with your Puller Pro to waterproof the connectors for the sensor wire. I just kept it simple and used Di-electric grease where the connection is on the motor. Both connectors on the sensor wire at the esc's male and motors female sensor plugs should be dabbed up too. I'm sure using conformal coating wouldn't work on those tiny prongs/connection's.
06-09-2017, 04:11 AM | #6 | |
| Re: Puller Pro 2200kv Quote:
@svt923, Never though I could use M3 Screws instead of glue. What a blessing I have you guys here. Thank you so much | |
06-09-2017, 07:53 AM | #7 |
| Re: Puller Pro 2200kv I wonder if the extra screws will interfere with the motor bolting down flush against the motor plate? It seems to me that may be an issue..
06-09-2017, 08:03 AM | #8 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Puller Pro 2200kv |
06-11-2017, 07:09 PM | #9 |
Puller Pro 2200kv - Similar Threads | ||||
Puller Pro - 2200KV 4S or 2700KV 3S? | ajsmcs | Axial SCX10 II | 67 | 02-15-2017 12:18 PM |
Pro puller 2200kv HELP.... | passinby | Electronics | 12 | 12-24-2016 11:21 AM |
Motor Selection Help Needed - HH Puller Pro 540 vs HH Puller Pro 540XL | WesTX | Electronics | 18 | 09-14-2016 09:16 PM |
Venom PRO Brusshles ESC and 540 2200kv 18.5T motor | BL-4x4 | Electronics | 0 | 01-03-2012 12:40 PM |
