01-30-2007, 05:13 PM | #1 |
Rock Stacker Join Date: Apr 2006 Location: Clovis
| A couple brushless ?s
First off, is a z3025 too much motor for a 2.2 TLT? I would like to have both torque and a little wheel speed if that's possible. second, if this scenario works out, would an RC4WD R2 trans hold up with that motor? Thanks |
01-30-2007, 05:26 PM | #2 |
You could build a 2.2 Twin Force. I run that motor,it would rip the TLT axles to shreads |
01-30-2007, 05:35 PM | #3 |
I'm wanting to stay with the scale-ish size of the TLT axles.
01-30-2007, 05:37 PM | #4 | |
01-30-2007, 05:57 PM | #5 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I have heard that the 3013 is good in a tlt based rig,I have one on order but it hasnt arrived yet so I can not vouch for it Devlin |
01-30-2007, 06:21 PM | #6 |
Thanks raptorman hotwheels, I look forward to hearing about it. What esc are you going to use? |
01-30-2007, 08:49 PM | #7 |
Mamba max per JRH recommendation, now I need to find a better lipo I dont think mine are going to cut it,Any suggestions????
01-30-2007, 09:30 PM | #8 |
I couldn't make any battery suggestions, I'm new to this. I'm still in the early development stages. |
01-30-2007, 09:45 PM | #9 |
Pebble Pounder Join Date: Jun 2006 Location: Flagstaff
I will be running the 3025 in a 2.2 rig with K1 axles, Portals, R2 tranny, 2s3p 3300 mah maxamp lipo, and mamba max esc I will have a 3013 as a back-up incase the 3025 is to much If it will turn a 20 lb. truck around I wonder what it will do to my BMVii I will post picks and let everyone know how RC4WD stuff holds up Last edited by sticksNstones; 01-30-2007 at 09:48 PM. |
01-30-2007, 10:05 PM | #10 |
sticksNstones, do you have a thread for your build? That sounds like something I should definitely take a look at.
01-30-2007, 10:08 PM | #11 |
It is being built right now by rockwerks and he should be done by weeks end. I will post pics when completed |
01-31-2007, 06:17 PM | #12 |
I think everything I would add has been covered. I would suggest the z3013 for a tlt, but a 3025 could be used. An inexperienced user could trash parts like nothing with the 3025. The r2 looks really beefy. I think it should hold up to the z3025 on smaller axles. Good lubrication would be very important |
01-31-2007, 09:15 PM | #13 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
the 3013 with a 8 cell 2/3a pack is all the power you could want! i just got my second one today and i cant wait to see it power my bmv2.
01-31-2007, 11:01 PM | #14 |
jrh- thanks for chiming in. I was hoping to hear from you, as you are the expert. I don't see the mamba max on your site, are you just out of stock. I'd like to price a package deal for a motor and esc. Would a z3013 bee like a built small block versus a z3025 as a built big block? With the right gearing can I get low speed torque and then punch the throttle for some wheel speed? Thanks everyone, I appreciate all the help and advise so far. |
01-31-2007, 11:04 PM | #15 | |
The 3025-8 would be more like a CTD with all the goodies | |
01-31-2007, 11:11 PM | #16 | |
Release your anger.. Join Date: Oct 2006 Location: North American Union
02-01-2007, 12:04 AM | #17 |
You can get a lot more wheelspeed with an outrunner and retain the torque for slower stuff, but there is a minimum speed that esc's can turn a non-sensored motor. Minimum speed for a mamba is about 200rpm on a 12 pole outrunner. Quark esc is about 80 rpm. You have to gear according to your driving style and voltage too.
02-01-2007, 03:40 PM | #18 |
Just installed the 3013 and went crawling, this motor works well. Cogging wasnt an issue and my lipo's seam to be up to par for the demand.I will try my 3 cell as I want a bit more wheel speed out of the r-2 trans. Thanks JRH |
02-01-2007, 03:52 PM | #19 | |
What lipo's are you running? mah and volts? Quote:
