Thread: Heyok light controller issue
Old 10-12-2018, 05:56 PM   #1
Default Heyok light controller issue
So ive had the controller for a couple of years now and it was working fine until i built my new rig and installed it. Hooked to my aux2 as a 2 pos switch on my spektrum dx4s. It now when turned on via the tx blinks the lights in no real set pattern. I have checked and played with all my tx settings but to no avail is the controller toast?
scalemadness is offline   Reply With Quote
Old 10-13-2018, 12:51 AM   #2
Default Re: Heyok light controller issue
are the end points where they should be? Should it be a momentary switch? try it again on the old system if you can. I don't have any hey ok stuff, these are just suggestions to look at.
Voodoobrew is offline   Reply With Quote
Old 10-13-2018, 11:16 AM   #3
Tried originally to play with the end points didnt make a difference in its operation still flashes off and on
Old 10-13-2018, 12:28 PM   #4
Send me a PM and we will figure this out!
heyok is offline   Reply With Quote
Old 10-13-2018, 03:24 PM   #5
Pm sent
Old 10-13-2018, 04:11 PM   #6
A huge thanks to Al (heyok) once again for helping figure this issue out! My switch has failed but only after alot of use and some not too friendly conditions so its a great excuse to upgrade light control as well as winch control with some more of Als great products!
Heyok light controller issue - Similar Threads
HeyOK KoH light and brake light controller. Jboucher Electronics 6 08-01-2018 04:30 PM
HeyOk Light controller setup nedmo Electronics 0 03-13-2018 05:29 PM
