Any chance to recover a glitchy ESC? I bought a used SCX10.2 and I noticed that when steering, the servo would be really choppy. At first I thought it was the servo, but it was buttery smooth with my servo tester. Then I tried a new receiver - same glitchy behavior. Then I installed a glitch buster, but no change. So I grabbed an extra Traxxas TRX-4 ESC, hooked it up and it works perfectly. So I've concluded that the Axial ESC is the culprit, but is there a chance to recover it? Is it worth taking it apart and cleaning in the internal components or should I just chuck this in a bin? |
Re: Any chance to recover a glitchy ESC? Bah, for 42 bucks you can buy a hobby wing esc that would give you plenty of voltage to that servo and it would offer a lot of adjustability to suit your particular driving style. Chuck it in the trash. |
Re: Any chance to recover a glitchy ESC? Is this an AE-5 ESC? I believe the board is encased in epoxy to make them waterproof so there really isn't anything that can be serviced. You can check for damage to the signal wire but any more that that probably isn't worth it on an ESC that can be replaced with something similar for $20 (Hobbywing 1060) or replaced with something infinitely better for $40 (Hobbywing 1080). |
Re: Any chance to recover a glitchy ESC? Quote:
I really didn't have any intention of keeping this ESC in this rig, but it's always nice to have a spare for other projects or for testing. Sounds like it's not going to be worth the trouble to save this one. Thanks for the input, folks "thumbsup" |
Re: Any chance to recover a glitchy ESC? Glitch busters don't work well in crawlers/scalers, putting a heavy enough load on the servo will drain capacitor quickly, leaving the electronics starving for power (brown-out). Recommend trying an external BEC with this ESC. |
This servo glitching could be seen even with a micro servo and no load, but I'm sure I would have gone through more steps to troubleshoot had I not found the culprit. |
Re: Any chance to recover a glitchy ESC? I wish I was a good enough engineer to fix an esc... but the return on that investment is really low, it that's my primary motivation. |
Re: Any chance to recover a glitchy ESC? You can try cooking it in a toaster oven... According to linus tech tips it works on video cards. Maybee do it outside... Needed to add a lol in here some where, cause seriously lol. https://youtu.be/8Xanr4jkmEc Sent from my SM-N950U using Tapatalk |
Re: Any chance to recover a glitchy ESC? the esc probably fried the internal bec try a external esc it dosent sound like a complete failure just for the hay of it use that extra esc just to power the reciver or use a small 2s lipo or maybe 2 aa batterys to make a quick test pull the power lead before hooking up the second power sorce you can lift the tab on the conector and slide the pin out of the conector so its easy to fix if for any reason you wanted to the glitch buster just provides a boost of power it wont make up for a week bec but it will take the load off the esc by providing the momentary power spike the servo needs to start the motor under heavy loads and realy helps when your wheels are bound and your trying to turn the wheels it also helps alittle with the heat build up |
