Thread: Boom goes the Savox!
Old 09-17-2020, 07:29 PM   #1
Default Boom goes the Savox!
Savox SA-1230SG
Purchased on August 3rd, on Sept 16th i noticed it was shaking after a backyard run.
Axial Bomber with a brushless Tekin 3100 in it
Not sure what i did but the center shaft is bent, front case broke, and the first large reduction is definitely worn in pretty well.
Warranty won't cover anything, not impressed with Savox Customer Service or the warranty at all.
Not even worth the 40$ to fix it up
Think I'm going to order a "Model T" from ServoAF as a replacement
Here's a video of the original issue; https://youtu.be/7K37v_UrhaM
NKlamerus is offline   Reply With Quote
Old 09-17-2020, 08:00 PM   #2
Default Re: Boom goes the Savox!
I've done that to a couple Savoxs over the years. Like you, discovered the "warranty" is useless and they weren't worth the cost to repair because a set of pins, gears, and upper case are almost 85% the cost of a new servo.
With your brushless bomber your going to need a fully aluminum cased servo to survive long term. Servos are really a buy once cry once type of deal.
I've discovered over the years that you can get away with cheap motors, esc's, radios, and even lipos. Not so with servos, especially on a rig with solid links, large tires, sharp steering and locked diffs. I'll pony up the $100 for a Promodeler 470 that goes in a truck that has less than that in the entire rest of the electronics.
meatmonkey is offline   Reply With Quote
Old 09-17-2020, 08:05 PM   #3
Originally Posted by NKlamerus View Post
Savox SA-1230SG
I’ll recommend the EcoPower WP120T. It has a metal casing and has right around 400oz of torque for $70 on AMain. I’m using it on my TRX4 with metal horn and it’s great
ScaleLifeNewbie is offline   Reply With Quote
Old 09-17-2020, 08:10 PM   #4
Ready to spend 100$ or more
The model t was specifically designed by someone who needed one for his bomber, biggest gearset ive ever seen in one.
1 year warranty
Old 09-18-2020, 06:52 AM   #5
Liking the pin diameter and gear layout on that Mode T, but I don't want to be the Guinea pig. You should put a whooping on it and let us know if it holds up.
Is it brushless?
Old 09-18-2020, 08:10 AM   #6
Is it brushless?
Yes it is brushless. Here's the whole gear set
There's a video on youtube explaining all the differences
Old 09-18-2020, 11:33 AM   #7
Yey..Savox is so great
Have a look at this---> https://www.agf-rc.com/servo-a80bhm-p2474391.html or this https://www.agf-rc.com/heightened-st...-p2728978.html
themountain is offline   Reply With Quote
Old 09-18-2020, 12:44 PM   #8
1 year warranty
Holy crap! I looked it up online. I like those recessed seals.
GTSLOW is offline   Reply With Quote
Old 09-18-2020, 12:53 PM   #9
Yeah they look great, they don't have a lot of information because they are so new
Only thing holding me back is it's a V1, which means if there are any kinks they haven't been worked out yet
But the videos and facebook info look promising
If I get one I'll definitely write up a review
Old 09-19-2020, 11:04 AM   #10
Wow thats crazy, I have broken plenty of servos but never split a case in half! Good job at total destruction!
Druxus is offline   Reply With Quote
Old 09-19-2020, 06:40 PM   #11
Got a link for the servo for us internet impared folks?
Sent from my SM-G970U using Tapatalk
Steve g is offline   Reply With Quote
Old 09-19-2020, 10:58 PM   #12
https://www.servoaf.com/
Met the owner through Facebook
Personally, I'm just glad it looks good. Simple build/body
A lot of the 100+$ servos are extremely gaudy
Old 09-26-2020, 06:57 PM   #13
Dang, I just may look into that for my E-Revo!
BJoe is offline   Reply With Quote
Old 09-27-2020, 12:04 PM   #14
That Savox looks like it went through a house fire!
Bansh88 is offline   Reply With Quote
Old 09-28-2020, 08:31 PM   #15
For sure spend the money on a big power servo!
size does matter is offline   Reply With Quote
Boom goes the Savox! - Similar Threads
2.2s BOOM ???? Frank211 Tires and Wheels 12 06-07-2018 09:50 AM
Boom !!!! Frank211 Traxxas TRX-4 6 02-23-2018 06:20 PM
...and boom ittybitty Chit Chat 14 02-03-2012 06:44 PM
Boom losikid Chit Chat 5 12-13-2011 12:37 AM
