07-27-2019, 03:37 PM | #1 |
Newbie Join Date: Jun 2019 Location: Rindge
| Front universal axle
Anyone else break a front universal yet? Broke a tab off one side of the axle that the pin goes through. Was just playing around on a vertical ramp and it grabbed a 2x4, broke the knuckle and the hub too. Stock replacement is $38. The whole axle kit is $75... The Axial ar44 axles look like they'll fit with a bit of work. any word if Vanquish or MIP have something for the Enduro yet? Last edited by Teamwild; 07-27-2019 at 04:05 PM. |
07-27-2019, 10:10 PM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Front universal axle Quote:
I'm working on a design using SSD pumpkin with a offset. Will weigh close to 5 oz. I should have some more photos up in my build thread next week. Ernie | |
07-31-2019, 08:56 AM | #3 |
I ended up buying the entire axle set from Element since it seemed like the better deal to get all the parts... also in the process it looked like the SCX10-2 axles were the same but I didn't want to spring for the Vanquish ones as I couldn't find any info online if they actually fit. I found some knockoffs on Amazon for $13 so I grabbed those to see what's up. Short story is all the measurements pretty much are spot on for the Enduro universals. If you look at the pics you'll see the $13 version is real thin where the stock universal broke so I don't expect them to last long, but next time I'd grab the Incision SCX10-2 universals and expect they'll be the hot setup. |
07-31-2019, 09:12 AM | #4 | |
SSD makes one that is very nice design, it's the one I use when building my axles. https://www.rpphobby.com/product_p/ssd00325.htm Ernie Last edited by CODYBOY; 07-31-2019 at 09:14 AM. | |
07-31-2019, 09:29 AM | #5 |
RCC Addict Join Date: Oct 2014 Location: UK
I found the Element universals bind easily and can see why they put steering limiters on the C hubs. If you change to SSD Universals then you dont need to limiters. They are a direct fit. Also after we release our knuckles and C hubs you will want the SSD universals to get maximum steering.
07-31-2019, 10:02 AM | #6 |
Nice info!
07-31-2019, 02:41 PM | #7 | |
Front universal axle - Similar Threads | ||||
looking for universal front body mount posts | 8000ft | Axial Yeti | 2 | 03-02-2016 08:12 PM |
Front Universal shaft Issue | 05Fronty4x | Axial Wraith | 10 | 05-02-2013 08:59 AM |
Front Universal Installation HELP..!!! | Land Crab | Axial Wraith | 17 | 04-16-2012 07:10 PM |
