Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Riddler X blue carbon "blurple haze"
Old 02-24-2017, 01:50 AM   #1
Default Riddler X blue carbon "blurple haze"
Hi guys I was lucky enough to get my new riddler x last week from hulksta engineering so I began straight away .
The biggest difference with the new riddler is way the feature shock works compared to the v1 riddler I don't have to run the spring anywhere near as hard as I did with the v1 and shock oil so much thinner whilst still retaining the about the same amount of opening . the shock actually works like a shock now and with adjustable preload it's a hell of a lot better.
Chassis :Riddler X blue carbon edition
With all 3D printed part options ( haven't arrived yet )
5th shock : trf 55mm with d3 cap and a 1.9 wire spring (still playing with oil)
Ally and tittianium hardware through out
Shocks front : scx .losi mini t rears silver 35 wt
Shocks rear : scx Rc bros springs 45 wt
Tittianium links : Mr Links riddler links
Blue rpm rod ends and traxxas ally balls
Axles :
dlux super lights : fully rebuilt
Delrin centres ,Delrin tubes ofna unis and 7075 8mm rear shafts 7075 lockers .
Gears : are a mixture dlux reduction gears
, Rcbros, Rc4wd
Knuckles : dlux delrin knuckles
Knuckle weight: home made carbon fibre tungsten slug holders run low and to fit a 2piece rim
Chubs : axial ax10
Wheels and tyres : herc team rims with gold dot voodoos
Electrics :
Servo : hitec 7980
Esc: HH brxl minis
Bec: castle 10amp at 7.8 volts
Motors : brood 40t Stubbys
Big thanks to my sponsors for all the support
Hulksta engineering
Mr Links
Jaycuts
So first things first I changed out the s/s hardware for purple ally saved almost 20g then set about the fifth shock
The shock is a tamiya trf with a d3 cap traxxas ally balls a 2mm wire spring and at the moment a mix a few drops of 5000 wt oil and the rest 100 wt oil seems about right
So last night I fully rebuilt my super lights
New front carbon gearbox plates
New bearings front and rear new tubes front and rear cleaned and re greased
Sitting pretty
Today my 3D printed chassis bits arrived
Saved a couple of grams
More to do but getting there
[IMG]
anonmule is offline   Reply With Quote
Old 02-24-2017, 05:05 AM   #2
Default Re: Riddler X blue carbon "blurple haze"
Sweet rig man, I dig it
Later,
Farmer
Farmer is offline   Reply With Quote
Old 02-26-2017, 02:12 AM   #3
So yesterday I shortened my links by 5mm on the front and 6mm on the rear then set the link mounts and set my clock mr links made me some kick ass titanium link sliders to suit the the 4mm to links
Today I set about the electrics.. the new smash fits in nicely
All but done for now time to get some tuning
Done
Old 03-10-2017, 10:15 AM   #4
Love it,,,
Only thing I would change is the center sections in delrin with 7075 Alu,, maby anodized in blue or purple
FLOKI-81 is offline   Reply With Quote
Old 03-10-2017, 12:25 PM   #5
Hi,
Would you have a video of it ? I can't see on pics which is the function of the 5th shock
CyberFox is offline   Reply With Quote
Old 03-10-2017, 08:47 PM   #6
Originally Posted by CyberFox View Post
Hi,
Look around on here. This is the new riddler. The old one had 2 shocks.
Amazing design. Search for riddler builds.
Looks awesome
jason1973 is offline   Reply With Quote
Old 03-10-2017, 10:16 PM   #7
Originally Posted by FLOKI-81 View Post
Love it,,,
This may happen yet bud
Old 03-10-2017, 10:26 PM   #8
Hi,
Video is uploading now bud I'll put it up on here when it's done .. I had one of the original v1 riddlers for the past couple of years running 1 shock the v2 had 2 shocks
Now it's back to 1 shock .. with the v1s / v2s shock location It tended to open when you didn't want it to ie. reaching for a ledge ect.
So we ran it super hard and super thick oil 60000 or so silicon oil it really only opened in V's or big binds now with the new location of the shock I'm running really soft and oil is at 100wt and it doesn't open up unless I want it too ... I'm super impressed with the new chassis and it a pleasure to drive
Old 03-11-2017, 04:22 AM   #9
https://youtu.be/mmHiuQOy25g
Old 03-11-2017, 08:48 PM   #10
That video is inspiring! Awesome crawler and great driving!
Will Murray is offline   Reply With Quote
Old 03-18-2017, 02:29 PM   #11
https://youtu.be/hbiOHXlPuxo
Old 03-18-2017, 02:29 PM   #12
Cheers bud
Old 04-06-2017, 12:18 AM   #13
So a little update ...
My new weight hangers to suit dlux knuckles arrived from shapeways the other day. They came up pretty good and I managed to fit an extra tungsten slug in it and still runs on a two piece rim
Old 04-08-2017, 02:14 PM   #14
Love your build Mr.Moss ;)
gabz17 is offline   Reply With Quote
Riddler X blue carbon "blurple haze" - Similar Threads
ManCaves "Purple Haze" Sand Rail TheManCave Non Crawler RC's 30 01-31-2014 09:25 AM
ColeWorx "Riddler" Buggy build... TattooKenny Axial Wraith 33 12-09-2011 07:16 AM
Coleworx "Riddler" build video joesbruiser Chit Chat 4 03-13-2010 04:11 PM
