Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: R1 newbie
Old 10-18-2014, 02:19 PM   #1
Default R1 newbie
Need some help with an upgrade I am doing to my R1. I am installing the upgraded skid pan that moves the links to the inside of the frame, but when installing the skid pan my motor is hitting the frame not allowing the skid pan to line up with the holes..... do I need to trim the frame or is their something I'm not seeing?
timscarcrazy is offline   Reply With Quote
Old 10-20-2014, 05:20 PM   #2
Default Re: R1 newbie
just got my r1 this past week, maybe posting pictures could be more helpful for others to give advise.
i am fallowing this as i hope to start hoping mine up too...
p.s.
what motor are you using?
navyeoseabee is offline   Reply With Quote
Old 10-20-2014, 05:50 PM   #3
I miss my R1. These are great crawlers!
I had to slightly trim the frame to run certain motors. It's really no big deal. The R1 tubes are beefy.
What motor?
tedo is offline   Reply With Quote
Old 10-20-2014, 08:30 PM   #4
Right now I am starting with a RC4WD 35t. Also i found the upgraded front links for the steering hit the pumpkin cover not allowing the fronts to turn very far
Old 10-23-2014, 05:50 PM   #5
I have been hearing horror stories on youtube of how hard the shocks are to build. I think they were the easiest thing to put together just make sure you use the small o-rings and use a regular wrench to tighten the caps. Mine haven't leaked yet.
Old 10-26-2014, 01:22 PM   #6
Also needing help with a battery. I am running a Savox 1258tg servo, a Spektrum SRS4210 receiver and a Axial AX24259 AE-2 ESC. The motor I am using is a RC4WD brushed 35t. What will be the best battery to use??
Old 10-26-2014, 08:31 PM   #7
I'm also relatively new to R1 ownership. I was running an AE-2 ESC on 4600 mAh 2S Lipo with no issues...except I reversed polarity accidentally and fried it.
Now I'm running the less expensive, but waterproof, AE-5 ESC on 2S or 3S and the same RC4WD 35t motor you have. 2S should give you decent wheel speed on that motor, and will work with your ESC.
I had similar issues with the upgraded steering links. On my buggy, the upgraded links were rubbing on the front axle skid plate when I used the 7 degree C-Hubs. I ended up putting the original links back on and fixed the turning radius by adding the 4 wheel steer kit and an extra servo. (My Futaba 3PL transmitter handles 4 wheel steer nicely.)
Chris B is offline   Reply With Quote
Old 10-26-2014, 10:02 PM   #8
Good deal thanks for the info
R1 newbie - Similar Threads
Newbie here !!!! Hi-Intentionz Newbie General 2 01-19-2012 10:18 AM
Newbie here!!!! Hi-Intentionz Texas 0 01-08-2012 10:12 PM
Newbie ChrisNick1222 Newbie General 5 12-20-2011 08:16 AM
I'm a newbie :) MotoMoo Newbie General 4 12-05-2011 02:35 AM
Newbie saying hi twicecustom Newbie General 18 10-02-2011 08:21 AM
