noname_rc's GOM kit plus 2 Attachment(s) Hesitated between this and a Bomber... Since i like to be different and always like Gmade... and i had a pretty good deal oh this one so... Gmade GOM kit plus... |
Re: noname_rc's GOM kit plus 4 Attachment(s) ... and the usual... shitload of upgrades ;-) |
Re: noname_rc's GOM kit plus Nice man! I can't wait to see how yours turns out. I plan to do the Axial Universal with Wraith knuckles mod, but I haven't gotten around to it yet. Should order up the rear shock brace and sway bar if you haven't already too. Someone also did a mod on the shifter block and replaced the plastic slider with a modified metal standoff piece. To help prevent the shifting from getting stuck. Other's have put washers between the shift housing to let it move more freely. I haven't done anything to mine yet, but I also don't shift that often on the fly and mine seems to be working so far. |
Re: noname_rc's GOM kit plus Quote:
As for the shifter, i add grease and will see how it goes, for now, it seems pretty smooth... I won't shift that often too so shouldn't be an issue here... |
Re: noname_rc's GOM kit plus 5 Attachment(s) And....... it's a go"thumbsup" |
Re: noname_rc's GOM kit plus 9 Attachment(s) And there it is... Tried it a bit just to see if everything's ok and damn, this thing is butter smooth..."thumbsup" Can't wait to put it to the real test... |
Re: noname_rc's GOM kit plus Nice!!! Lovin’ that sticker-bomb theme. |
Re: noname_rc's GOM kit plus Holy moly, that steering column though. Looks 5 feet long in 1/1 |
I know:roll: Close up is terrible but doesn't look that bad from a distance |
Re: noname_rc's GOM kit plus 8 Attachment(s) This thing's a beast... Crawl very well and enought wheelspin to thorw rocks around ;-) |
Re: noname_rc's GOM kit plus 2-speeds transmission works like a charm, so do the dig... Very versatil rig... |
Re: noname_rc's GOM kit plus Nice man! |
Re: noname_rc's GOM kit plus That's seriously rad. What's parts availability like for the Gmade trucks? |
Re: noname_rc's GOM kit plus I just snapped another pin on my front axle and would recommend using longer 12mm axle pins (stock is too short by a hair) as well as the barrels with set screw from this kit https://www.rpphobby.com/product_p/jun90131.htm though Junfac may have the barrel all by itself by now possibly. The barrel with set screw keeps the pin in place, when its allowed to move it tends to break (meaning the stock setup) More info and pics on the axle pins and barrel here http://www.rccrawler.com/forum/g-mad...ml#post5824529 http://www.rccrawler.com/forum/g-mad...ml#post5806202 |
