Big outrunners with what? Those of you running big outrunners, what tranny are you using? I'm trying to build this badass truggy with a 3020 Scorpion and WK axles. I've got an Emaxx tranny but man it's hard to build around. Anyone had luck with a R2HD? Could I even put the Scorpion in it? I'm trying to get this thing built, but every time I try to design something the Maxx mounting options f*ck me over. |
The tranny in my Scorpion rocks. Very smooth, and I've only heard of one failure on this board out of all the folks running them. |
I'm quite sure an Axial tranny could handle it. Especially if you had a tight slipper on it. |
I've got the 3020-14 in my x-factor super with a VXL-spec stampede tranny. I've seen old pede tranny's go for $25 and the steel iternals are around $15. Unless space is a factor I'd run that over the axial but that's just my opinion. |
Hmmm... I'll try the axial and then the pede if the AX explodes on me. I'm not the guy that hammers on it when i get a wheel stuck or anything. I actually drive my trucks pretty easy from what I've seen other people do. |
I wouldn't be worried about the gears in the Axial, so much as the output shafts. I have had a failure and heard and read about many others who have broken the output from the tranny locker. I was using a 55t lathe motor. |
I would use the HD RC4WD R2 before I used anything else. No matter what, with that big of a brushless motor, you are going to break stuff if you get bound up:twisted:. Every time I run brushless in a rig, it breaks something. The torque from brushless is amazing. I just wish it was buttery smooth like a lathe. |
I think the axial would be fine if you put a slipper on it. Here is a slipper that fits. http://www.rccrawler.com/forum/showt...hlight=slipper |
I'm leaning to either a TXT or a RC4WD HD. I don't want to use a slipper and I need 6mm shafts to run Maxx shafts. |
i'm running an holmes hobbies crawlmaster on an r2d and it's going just fine... mamba max...2.2 wheels plenty of power 2100 3c lipo... 12t pinion scorpion axles...verrrry happy with this combo |
i actually just stripped the gears in an axial tranny yesterday running a revolver with a 3 cell lipo. maybe look at something beefier |
I would use a 'pede,my Hyperion/MM combo hasn't blown up mine yet,yet being the key word.I have TXT axles and Maxx Mashers with Maxx shafts in my rig |
Well, I've changed my mind to running a 3025 or a 3032. I'm REALLY leaning towards the TXT tranny. I'll need a custom motorplate to run the 3032. |
