revo rod end size? can someone show or tell the the size diffrence from the regular traxxas rod ends and the revo ones? i want to run 3/8's links but dont want big links with little rodends. or if you know of any rodends that are about that size. thanks |
If you're looking for a larger rod end, you could try the Kyosho one's like what are used on the Inferno's: http://www.amainhobbies.com/product_...oducts_id/3854 which are more like 8mm (roughly 5/16") .....or these: http://www.amainhobbies.com/product_...oducts_id/6046 which are about 10.5mm (a hair larger than 3/8") |
i used jato rod ends ,they are just over1/4 inch dia. and drilled out my links to 8/32 and havent pulled a link off the thread since ,the 3mm axial uses is just to week."thumbsup" |
1 Attachment(s) Here is a revo rod end on a 3/8" rod (the black ones where the shocks are supposed to go), just taper the ends a bit and it will look awsome. |
thanks kamikaze! i think thats what i will do. |
I'm with Jeff. Revo rodends are the way to go. I put them on every thing. Just need an 8-32 drill and tap. http://i279.photobucket.com/albums/k...A/397f2239.jpg And yes 3/8" rod will fit over them.;-) |
1 Attachment(s) I use 10-24 all thread in my Revo and Jato rod ends. Then sleeve it with 1/4" SS tube. "thumbsup" |
