08-12-2004, 09:41 PM | #1 |
Pebble Pounder Join Date: Jan 2004 Location: Santa Cruz California
| New Crawler for the Comp!!
Finally got her finished. The car is a tube framed crawler with TxT-1 axles, and tranny. The main thing about this chassis is that the tranny is flipped upside down for lower COG. The first proto-type didnt have savage shocks, and didnt work or look right. Now with the savage shocks it seems much more stable and smother when articulating. We'll here's some pics! This was the chassis before I modded it for the savage shocks |
08-12-2004, 09:44 PM | #2 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
| Re: New Crawler for the Comp!!
About time.
08-12-2004, 09:50 PM | #3 |
WOW 8O , that looks sweeeet Guru. Awsome scale looks. I hope it rocks for you at the comp. |
08-12-2004, 09:59 PM | #4 |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
Nice build, I like the front clip idea, I was going to do that. :? Oh well I will find some for the tlt.
08-12-2004, 10:16 PM | #5 |
Quarry Creeper Join Date: Jun 2004 Location: aurora, CO
lmao! mine is pretty similar to yours, and i too had the same idea too! great minds think a like eh? looks great though!! question do you think your springs could be softer? im running pretty much the same setup and it seems a bit stiff |
08-12-2004, 10:47 PM | #6 |
I'm not really having any problems getting it to articulate, and I'm runnning 80 wt oil in them.
08-12-2004, 11:06 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
looks great
08-13-2004, 01:37 AM | #8 |
Quarry Creeper Join Date: Jan 2004 Location: Austalia
looks awesome ryan |
08-13-2004, 01:40 AM | #9 |
Quarry Creeper Join Date: Mar 2004 Location: VA
Looks good. I like the Cruiser nose . Also can you tell a real difference with the inverted tranny. I thought about doing it with a E-maxx tranny but havent had the funds to build another crawler yet to see if it worked.
08-13-2004, 02:10 AM | #10 |
I definately think it helps. I dont have any shaft twist, which was the main difference. I'm sure you would also notice more of a difference running two motors, because right now I'm only running one. It really wasnt that hard. The truck has 4 inches of clearance under the chassis right now and had 5 inches at first. The drive shafts didnt bind at 5 inches but 4 just seems to work better. Plus if you were to do it with a maxx tranny it would probably be much easier. Because the TXT tranny is oddly shaped.
08-13-2004, 06:50 AM | #11 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
I li8ke it. Especially the functioning hood. Also the square look of the frame looks great and old school.
08-13-2004, 07:55 AM | #12 |
Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
That is very cool. Very good work. Keep it up.
08-13-2004, 07:56 AM | #13 |
08-13-2004, 09:29 AM | #14 |
Rock Crawler Join Date: May 2004 Location: Calgary
Damn that thing is nice. I really dig the simple square look for the frame/body. You people and your tubers.................it's just not fair...........why can't I know how to weld! |
08-13-2004, 09:55 AM | #15 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
Sweet! One question, why didn't you run the battery below the drive shaft...?
08-13-2004, 11:04 AM | #16 |
Pebble Pounder Join Date: Aug 2004
Awesome truck 8O ! Makes me want one even more Looks heavy-duty, too! -Casey |
08-13-2004, 03:18 PM | #17 |
Quarry Creeper Join Date: Apr 2004 Location: Louisiana
I see that you changed your mind on the rear from the first pic. I really want to build a tuber but I have just been lazy. After seeing your cruiser and the tubicon I really want to make a scale version of my 1:1 Heep (minus the rockwells). What welder did you use? All I have is a Millermatic 175, If I turn it all the way down I think that I will burn strait through the brakeline. Also, what are you using to clean up the welds, a dremel or are you using some sort of bondo-ish filler. |
08-13-2004, 07:27 PM | #18 |
For welding I just used a simple 120 mig welder. But I didnt use brakeline, I used solid rod. I like to be able to jump on my cages when I'm done. The weight isnt even bad at all it weighs maybe a pound more then the stock TxT-1. To clean up the welds all I did was use a dye grinder.
09-05-2004, 08:40 PM | #19 |
How did you strip the chrome off of the wheels?
09-05-2004, 08:43 PM | #20 |
Quarry Creeper Join Date: May 2004 Location: portland OR
its spray paint bud
