Thread: Evolution [56k should be ok]
Old 09-15-2005, 08:36 PM   #1
STS
Default Evolution [56k should be ok]
Stage 1: Here is how it started after I changed the body.
Stage 2: tummy tuck, with the axle reversed, tires cut and reversed (yes back tires are forward but dont be nitpicky), body trimmed but I had to remove the grill and had to cut out most of the bed.
but the axle started clicking, I tried tightening the bolts on the tranny but it kept it up. The problem seemed to be the whole assembly shifting when forward throttle was applied
Stage 3: So axle went back the right way and on went the 2.2 MOABS. I sealed the PCB and put the battery under it. It was difficult to get to the battery so I went back to the scorpion body and cut out the floor board. I also moved the ball mounts to the opposite side of the mount because it was binding.
Here is my playground, pictures dont do it justice:
I need to get some action shots but I couldnt get to the camera and I was too excited to get the 2.2s tested.
Next, better battery, electronics, and suspension refab.
STS is offline   Reply With Quote
Old 09-15-2005, 09:57 PM   #2
So when you flipped the axle back forward it quit clicking? I have a reversed axle on 2.2 moabs and it started clickin b4 i put the 2.2's on it. Now it won't quit, and i keep checking none of the gears are stripping. I think i'm going to flip the axle back since now i have more clearance.
034x4 is offline   Reply With Quote
Old 09-16-2005, 10:31 PM   #3
STS
yeah the clicking stops, now it only does it if I get her really bound up in reverse.
Sorry the pics arent appearing my host server went down or something.
Old 09-18-2005, 08:13 PM   #4
STS
some more pics with stick like suspension, and reshortened wheelbase. (it will be extended again.)
all pics (except the ones with it sitting on the stock tires) driven into and out of (and rolled out of 1 or 2 :-P ).
