Thread: gyros?
Old 04-05-2009, 10:40 PM   #1
Default gyros?
i don't really know how a helicopter gyro works but if it does what i think it does, you think it would work in a crawler to help keep it on it's wheels?
axial-aaron is offline   Reply With Quote
Old 04-05-2009, 10:48 PM   #2
My boss is a helicopter guru, we talk about this stuff all the time. His consensus is that a gyro reacts to slowly to a motion to help out a crawler. Learn to drive........ Dang......his name pops up first on google....he must be famous
Kamikaze is offline   Reply With Quote
Old 04-05-2009, 11:06 PM   #3
i know how to drive i just thought it would be cool to make an insnane vehicle be even more insane
Old 04-05-2009, 11:11 PM   #4
Hehe
Old 04-06-2009, 08:38 AM   #5
Gyros on a copter affect controlled surfaces of the blades and servos, etc. You have none of that on a crawler. Simply adding a gyro will not do a thing in my eyes. Hook a gyro to a steering servo and you have what? A counter-balancing effect on the steering?! That negates the point. You would need separate control surfaces, i.e. servos on each side of the axles or attached to limiting straps on the axles. Waste of time.
O.C.D. is offline   Reply With Quote
Old 04-06-2009, 08:46 AM   #6
dammit, I thought this thread was about sandwiches :-(
helhedded is offline   Reply With Quote
Old 04-06-2009, 08:55 AM   #7
cartronicshn's Avatar
cartronicshn is online now   Reply With Quote
Old 04-06-2009, 08:58 AM   #8
Gyros on fast cars can be used to control drifting and keep cars going in a straight line. I've actually been thinking of trying one in my slash.
On crawlers I don't really see a need for one at all
engineerjoe is offline   Reply With Quote
Old 04-06-2009, 09:04 AM   #9
I've heard about these on drift cars, do you own one? i have a drift car and was thinking about trying one, although i have no idea what kind of gyro to use, sorry for the threadjack.
Old 04-06-2009, 09:05 AM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You could build a self balancing rig if you wanted. Not much use for crawling, but it would be cool anyway.
JohnRobHolmes is offline   Reply With Quote
Old 04-06-2009, 10:27 AM   #11
I've used or dealt with a number of heli gyros and one thing I've learned is that they work well for their intended purpose, but usually do not so well (if at all) for any other use. Has to do with the way they are tuned specifically for heli dynamics and installations.
Not to discourage you though. You could try checking out the robotic hobbyists 'cos they get off on this kinda stuff. Or you could pick up a cheap basic gyro like the GWS PG-03 http://www3.towerhobbies.com/cgi-bin/wti0001p?I=LXMSF8 and just experiment with it.
Go ahead, have some fun!
Cheers.
Terranaut is offline   Reply With Quote
Old 04-06-2009, 08:03 PM   #12
HPI actually makes(re-brands) a gyro for drift cars
http://www3.towerhobbies.com/cgi-bin...&I=LXMVE1&P=ML
I'm planning on using one on my 73mph OFNA 1/8 onroad to help keep it in a straight line.
gimpygolden is offline   Reply With Quote
Old 04-06-2009, 08:07 PM   #13
mhm gyros.
Mr.Slave is offline   Reply With Quote
Old 04-07-2009, 02:12 AM   #14
Got an interesting idea (free feel to point and laugh), what about having an extra servo that could automatically shift weight from one side the axle to another. Kind of like an abacus or something. I could see having weight shifted toward the wheel highest in the air could prevent roll-overs. hummmmm
Cheers,
DC
Bigcatnearmiss is offline   Reply With Quote
Old 04-07-2009, 03:34 AM   #15
Originally Posted by Mr.Slave View Post
mhm gyros.
X2! UUUUmmmmm............Looks Good!!
clodbuilder99 is offline   Reply With Quote
Old 04-07-2009, 08:30 AM   #16
ok...maybe not a helicopter gyro but maybe some other type of gyro. it just seems like a cool idea. got it from changing the tire on my bike(spin it then try to flip it over)
Old 04-07-2009, 09:31 AM   #17
Aaha!! I think I get the drift. You want the rock steady stability of a spinning wheel gyro to prevent the rig from rolling over? I believe it's been done on ships and trains before. There are some issues with the idea, it would take a page or three to explain, and I'm no expert.
I can tell you that model heli gyros these days are solid state, not spinning wheel, so they have no inherant stability themselves, they are just a rotation rate sensor. They could function through another mechanism, but you'll have to get creative!
Cheers.
Old 04-07-2009, 08:48 PM   #18
i read somewhere that the old rc helicopter gyros were mechanical gyros(spinning flywheel, inside i guess). would this be sufficient?
Old 04-07-2009, 09:01 PM   #19
Interesting idea. I had the 'ol brass wheel gyro in mind when I saw the thread title. Powered by a small brushless motor and actuated by a servo, it could be used to counteract motion on a certain axis. To manipulate it manually would be quite a feat of co-ordination, but if you could program it to kick in at the tipping point and buy yourself a half second to keep from flipping, things could get interesting!
derangboy is offline   Reply With Quote
Old 04-07-2009, 10:03 PM   #20
Yeah, like this one, only no tomatoes for a lower COG
durango#95 is offline   Reply With Quote
