Thread: Rear steering
Old 08-21-2011, 08:15 PM   #1
Default Rear steering
Just got done with my home engineered rear steer on my E-Maxx, took it out for a test run and noticed my rear alignment will not stay constant, the
rear wheels turn on their own. I believe I have traced it down to the servo saver I installed, I think the spring is way to soft and allowing my issues. it is just a general use stock Traxxas unit.
Anybody know of a good somewhat stiff springed servo saver that
I can try?
I may have to run a solid servo horn just to keep my alignment and have
it track straight when not using the rear steering.
I'm running a good high torque metal geared servo
Any advice would be appreciated
Thanks
Steve
nvradtec is offline   Reply With Quote
Old 08-21-2011, 09:13 PM   #2
I'd say get rid of the servo saver
demonoid369 is offline   Reply With Quote
Old 08-21-2011, 11:52 PM   #3
Are you going to be running it at crawl speeds, or will you be going fast. If it is only crawl speeds, then I agree, ditch the servo-saver.
...and where in the hell are the pics/video?
Greatscott is offline   Reply With Quote
Old 08-22-2011, 12:50 AM   #4
That's the way I'm leaning dump the servo saver for an aluminum servo
horn, if I use a plastic one there may still be to much flex, now to find an L shaped aluminum servo horn
Old 08-22-2011, 07:20 AM   #5
Your mistake was building what I'll assume is a pretty awesome rear stear mod and using a piece of junk Traxxas saver. Traxxas savers are prone to wearing out and are weak all around. Get yourself a quality Kimbrough saver for whatever servo you have and you'll be much happier.
federally is offline   Reply With Quote
Old 08-22-2011, 08:32 AM   #6
The Ofna Heavy-Duty servo savers (CPE-SER3) are what we use on our Clod racers. Much stiffer than a stock Traxxas one would be.
CPE MT is offline   Reply With Quote
Old 08-22-2011, 12:31 PM   #7
Just order 3 of the Ofna's, the traxxas version is the only one I had left in the toolbox when I completed my mod.
What servos would you guys recommend, right now I'm using a couple
JR Racing 650 metal geared servos
Old 08-23-2011, 01:01 AM   #8
In my Scx10 I run an Airtronics 94851 200oz torque at 6v metal gears and $43! Savox have some gret servos as well, have some of them in my other Rcs
Old 08-23-2011, 09:39 AM   #9
Is this a basher rig or a crawler? Since you said it was a emaxx, I'm just wondering because bashers don't really need a super strong servo like crawlers do. So if you plan to crawl-get a stronger servo in the 250oz range and up ish but if it's just going to be driving around like a normal emaxx lol then one of tue cheaper and less powerful servo's are needed
Old 08-23-2011, 10:48 AM   #10
Mostly a basher and doing some crawling, but still want strong servos
Old 08-23-2011, 11:59 AM   #11
Then either hi-tech, spektrum, JR. Just look for one in the high 200oz range or 300oz, just depends on how much you want to spend
