Thread: Losi springs, what are they originally for??
Old 01-20-2007, 11:52 AM   #1
Default Losi springs, what are they originally for??
Ok I bought some white losi springs for my sw2. Im running stock 2.5 maxx shocks. The springs were for a MLST2 which I suppose is the mini lst. I didnt look to see what they fit before I picked them up. They are a little smaller diameter and lots shorter. I got the wrong ones didnt I? What do the ones everybody uses fit on?
maxboostbusa is offline   Reply With Quote
Old 01-20-2007, 12:51 PM   #2
2006 2.2 National Champ
BENDER's Avatar
Part # LOSA5147?
That's the part number you want. They are actually buggy springs. You can use preload spacers to make up for the shorter height, or pick-up some cheap threaded bodied shocks. The diameter is a little smaller, but they should still work.
BENDER is offline   Reply With Quote
Old 01-20-2007, 12:58 PM   #3
cartronicshn's Avatar
Hi bender, those are the white losi right? i have pink losi from an older buggy have any idea if they are stiffer or softer?
Sorry for the threadjack
cartronicshn is offline   Reply With Quote
Old 01-20-2007, 01:00 PM   #4
BENDER's Avatar
That part number is for the white Losi springs. The pinks should be stiffer. The only Losi spring I know of, that is softer then the whites, is the greys.
Old 01-20-2007, 01:08 PM   #5
thanks bender , i will get a set of white an grey to test out.
Old 01-20-2007, 01:18 PM   #6
For future reference, here is a list of Maxx shock sides springs from the Losi site. It lists, manufacturer part number, length, spring rate, color and recommended price.
LOSA5147 2.75" Spring 1.8 Rate,Wht 2.50
LOSA5148 2.75" Spring 2.0 Rate,Yel 2.50
LOSA5150 2.5" Spring 2.3 Rate,Pink 2.50
LOSA5152 2.5" Spring 2.6 Rate,Red 2.50
LOSA5154 2.5" Spring 2.9 Rate,Orange 2.50
LOSA5156 2.5"Spring 3.4 Rate,Silver 2.50
LOSA5158 2.5" Spring 3.7 Rate,Green 2.50
LOSA5160 2.5" Spring 4.1 Rate,Blue 2.50
JeremyH is offline   Reply With Quote
Old 01-20-2007, 01:58 PM   #7
thanks jeremy
Old 01-20-2007, 03:51 PM   #8
If you're using the t-maxx shocks, the 2.75" are the ones you want. I have the LOSA5147 2.75" wht. and they're perfect on my sw2.
calyakker is offline   Reply With Quote
Old 01-20-2007, 04:35 PM   #9
i'll probably end up buying one of ea. as i have the maxx shocks, but have a whole bunch other shocks different lenghts
Old 01-20-2007, 06:32 PM   #10
Thanks everybody. Got some on order now.
Old 01-20-2007, 06:54 PM   #11
I'm a stupid C U N T!
last i checked the gray's were disco'd and the whites are limited production
slobin3d is offline   Reply With Quote
Old 01-20-2007, 07:47 PM   #12
MWRCA'er
Mnster's Avatar
I've got a pair of grays and whites on my TLT, seems to be the perfect spring rate.
Mnster is offline   Reply With Quote
Old 02-04-2009, 01:39 PM   #13
Old thread but what diameter are the Losi 1/10 springs for example the 2.75" ones ?
cyberdog is offline   Reply With Quote
Old 06-05-2009, 04:42 AM   #14
There are also the Gold Springs
LOSA5144 2.75 Spring 1.4 Rate, Gold
I know this thread is super old just thought I would update since peopel still look for this sort of thing
grimace360 is offline   Reply With Quote
Old 06-05-2009, 07:01 AM   #15
Thanks Grimace. I dont think they had those when I posted that info...
