scx10 suspension geometry sorry if this is the wrong part of he forum if it is just let me know, il delete/repost. to the point. im thinking about changing the shocks on my sx10 to something longer for more clearance and to accomidate some bigger tires. if i went to say 110 mm shocks, would the links bind and would the yokes be alright? i dont wanna shell out money for somethin that wont work. also would i be better off buyin some dual rate coil overs, somethin similar to whats stock, or would those scale plastic shocks work alright? -thanks a lot |
The geometry will be fine. The only thing that will change in your pinion angle and your wheelbase will shorten just a little bit. You might want to lengthen you upper link to bring the pinion angle back up. |
ok thanks. i already have spacers in the upper trailing arms.instead of the regular servo plates though, i have http://www.tcscrawlers.com/On-Sale-3...g-p-16613.html on there front/rear.i was thinkin of putting either 1.9 or 2.2 rok lox from rc4wd and then http://www.tcscrawlers.com/RC4WD-Dua...0-p-17710.html also real quick, how well do http://www.tcscrawlers.com/RC4WD-Sca...0-p-17170.html work? thanks |
