12-31-2005, 11:55 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: CENTER
| help
after i did the low gear mod i cant get the side of the case closed were the motor is.ive dremmeled everything i can find.and also do you run it in low or high with the mod?
01-01-2006, 12:14 PM | #2 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Did you read my page? http://www.toyotaoffroad.net/afertig/88/nylintredux.htm I drilled a hole in the top of the case and ran a zip tie through the case to keep it together. You can run it in either low or high. Low will be SUPER low, and high will be your old low. Your faster high gear is now gone. |
