Thread: Cutting the springs when limiting shocks?
Old 01-15-2010, 02:03 PM   #1
Default Cutting the springs when limiting shocks?
Just curious if it is common practice when you limit a shock's travel internally with say some tubing, do you cut the springs down by the same amount?
jkwrangler08 is offline   Reply With Quote
Old 01-15-2010, 02:40 PM   #2
Normally I have seen people run the same springs with less preload, or get softer springs.
Greatscott is offline   Reply With Quote
Old 01-15-2010, 04:52 PM   #3
it wont sit in the retainer properly
chris w is offline   Reply With Quote
Old 01-15-2010, 06:43 PM   #4
Was wondering about that..
Thanks..
