no front power I recently bought a 1:18 nylint jeep, and after the first day of using it hard the front tires don't grab. when i pick the jeep up, they spin, but when they come in contact with an obstical they just stop. any ideas whats wronge? |
Moved out of Tool and Procedures into 1:18 forum where it belongs. |
make sure your switch is in low or high(same as rear axle) could be the motor support in axle broke off causing the motor to push over & slip gears(fix with electrical tape if so) |
i figured it out, after tearing the whole high/low assembly apart i saw the metal gear for the low had stripped the plastic part, just bent the tabs and filled in the grooves with rubber cement and made every thing a little tighter and it runs well. |
