Thread: Removing blue arms
Old 01-22-2006, 05:43 PM   #1
Default Removing blue arms
how are trhe blue arms held onto the actual body?? I need to get them off? Any help would be great! Thanks!
zach3713 is offline   Reply With Quote
Old 01-22-2006, 05:49 PM   #2
they are held on by the round plastic peices on the inside if you break them of you will have to make new ones
FroggF350 is offline   Reply With Quote
Old 01-22-2006, 07:39 PM   #3
I neeed to get the pins/screws whatever they are out of the blue piece on the body....it's not just some round plastci piece..
Old 01-22-2006, 08:02 PM   #4
The metal piece is like a rivot the plastic on the inside holds it in place to get the pin out you have to break the plastic piece and once you do that you have to come up with some other way to keep the metal pin from falling out, some people have made them out of aluminum. I just made clips for mine so i could remove them when i neede to! So yes it is just some round plastic piece
Old 01-22-2006, 08:32 PM   #5
Ok, you were right, sorry for doubting you we wenr't using our entire brain at the time....got it off...now it's time for a MAJOR lift...
Old 01-23-2006, 04:49 AM   #6
good luck im looking forward to seeing the pics
Old 01-23-2006, 10:18 AM   #7
ill get them up asap
