Thread: Who made there wheels?
Old 02-03-2011, 03:43 PM   #1
Default Who made there wheels?
Im out of the hobby now, bought these over a year ago and dont recall who made them. The outside ring holds stainless balls inside the wheels for weight.
Thanks!
blt-2-drg is offline   Reply With Quote
Old 02-03-2011, 03:53 PM   #2
Defy Gravity
Mayhem Engineering
ghtpdm5 is offline   Reply With Quote
Old 02-03-2011, 03:55 PM   #3
Thank you!
Old 02-03-2011, 05:40 PM   #4
Originally Posted by ghtpdm5 View Post
Mayhem Engineering
+1....similar to a Mayhem double phatty (so you can do a search on their site......)
Charlie-III is offline   Reply With Quote
Old 02-03-2011, 07:02 PM   #5
Those are the Comp Double Phatties.
Standard Competition Double Phatty
2.2 Beadlock Wheels with Live Weights
$130.00 + $12.00 shipping within the USA
Part Number ME-1004-Comp (Aluminum or Black Delrin)
Rims available in Aluminum or Delrin
The benefits of this design:
Need only remove outside locking ring to adjust weight
No need to remove the tire, saving time
Adjust weight by adding or subtracting 9/16" ball bearings or stationary weights (stationary weights not provided)
Just about any type of wheel weights (other than bearings) can be used
Ball bearings will always stay at the bottom of the wheel to keep center of gravity at its lowest point
Largest ball bearing 9/16" or smaller can be used
The key to this design using any type of ball bearings is to KEEP them below center line of the wheel; if above center line it will not work as intended. If you are above center line the bearings have a tendency to flop over the top and lose the benefit of keeping the center of gravity at its lowest point.
This design doesn't add a lot of weight, but what weight is there keeps the center of gravity at its most useful point (low in the wheel. Specs: Aluminum CDP Weight Rim Only 6.5 oz Rim, Ring & Screws 8.4 oz Rim, Rings, Screws & BB(4) 10.1 oz
Specs: Delrin CDP Weight: Rim Only 3.5 oz Rim, Rings and Screws 5.4 oz Rim, Rings, Screws & BB (4) 7.1 oz
jcboof is offline   Reply With Quote
Old 02-03-2011, 08:26 PM   #6
Thanks guys. Sick wheel, too bad i never got a chance to use them.
