AX10 vs SCX10 I was wondering if the scx10 chassis is capable as the ax10 chassis when it comes to climbs, suspension articulation and etc. |
Absolutely not....the AX10 was designed as a Comp Crawler (back when Shafties had a chance) and the SCX10 while it shares some basic components like axles and tranny has a different frame and shock setup as it is a SCALE truck. While the SCX10 does surprisingly well as a scale truck it does not articulate as well as the AX10....as far as traction, climbing, ect it all depends on the weight distribution and tires on each rig |
can the ax10 chassis can be used as a scaler though? |
Well, really you can do what ever you want with it... but, no. The AX 10 is not a scale chassis, it's a comp chassis. You can mount a scale body on it if you want to... |
With a little bit of fiddling and modifying my SCX outperformed my AX10 in pretty much everything I have run them threw, I don't find the limited travel a hinderance at all as all my rigs are strapped down anyways. Right now, I am running a truggy SCX with all factory suspension mounts besides the rear shock mounts and I love it. In FOFF mode it climbs better then my buddies FOFF AX10, very similar setups on both. Great truck stock, my only suspension mod is shocks and stretched wheelbase EDIT* and the axial kit 4 link truss |
Thanks, I think I decided to build two rigs, one comp and the other for a scaler. |
as mentioned the ax10 is more of a comp crawler vs the scx 10. i have both rigs and i must say i have better performance with my scx10 than my ax10, the ax 10 is nice and does good, but a lil upgrading would make it a much better crawler. first day i took it out i destroyed the yokes and the battery needs to be relocated to a much lower cg,plus some metal links would help |
