12-21-2011, 06:55 AM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| Punishershaft ??
I need a driveshaft with a 150mm max length and want Punishershafts. Will the 120-150mm be ok being at the max length I need ? Thanks Joe |
12-21-2011, 07:39 AM | #2 |
| Re: Punishershaft ??
IMHO I wouldn't run the shaft listed for max length as the contact area between the male and female ends is much shorter. I'd go for 123-165mm Punisher. Extended Punisher Shaft for AX10 123-165mm 4.84"-6.49" If it's too long you can always grind down both ends or just the female end. What rig is this going into? Lol I had to find a shaft a super long enough for my CC-01 Tundra IFS project still in the works. With the stock CC-01 shaft made for around 9.5"-10.5" wheelbase. Now putting on a Tundra hardbody that's 12.3" wheelbase I had to do some thinking. This was a bunch of Traxxas half shafts CA'd together with a little give at the last shaft on the rear diff output. I measured my Traxxas half shafts and needed a tad bit over 9" shaft (around 230mm or so). Since then I swapped to the Punisher II Super Long 195-237mm . I'm running the stock silver can for now just for trail running may upgrade motors later. Now the question is how long the tranny gears will hold up! Last edited by alexchen86; 12-21-2011 at 07:43 AM. |
12-21-2011, 10:05 AM | #3 |
Thanks for the reply I didn't want to use the 150 shaft, just couldn't find the one you linked. It is going into a custom framed NewBright JK I'm doing.
12-21-2011, 04:43 PM | #4 |
Awesome glad I could help. The Punisher shafts come with no grease so I'd recommend putting white lithium between the splines or Lucas red n tacky. Even on MIP shafts I apply white lithium after the blue loctite is dried for smoother movement and keeps water out.
