08-03-2006, 12:30 AM | #1 |
Rock Crawler Join Date: Mar 2005 Location: Murrieta
| tuber nylint
has anyone done a tuber nylint I wanna make a new chassis out of 1/4" brakeline to replace the plastic cage. it will be 4 linked |
08-03-2006, 12:32 AM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Yes, I forgot who though, and it was 1:18! |
08-03-2006, 12:36 AM | #3 |
ive seen 1/18 I want to see if anyone has done a 1/6 if not im gunna |
08-03-2006, 03:25 AM | #4 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
I think mudinyeri attempted it and a few others (tube). Four-linking the rear is cake but good luck with the front. I've tried for hours to get a workable 4-link system for the front axle but failed. With that steering motor there, it's very hard to get the links parrallel and not bind. I ended up four-linking the rear and making new arms to replace the blue ones up front. |
08-03-2006, 06:34 AM | #5 | |
Rock Stacker Join Date: Jun 2006 Location: staring in your window
08-03-2006, 06:38 AM | #6 |
Quarry Creeper Join Date: Aug 2005 Location: Omaha
I had one about 75% done but I just couldn't find a link setup for the front that I was happy with. You can do a search on my user name and find the build post. I'll sell you the chassis and links and rear axle with the link mounts on it if you want.
08-03-2006, 09:35 AM | #7 |
00TJ-Nice looking Nylint. Can we see a better pic of it?
08-03-2006, 02:39 PM | #8 |
Newbie Join Date: Aug 2006 Location: Mesa
could you post a clearer pic of your steering link. the link that came with my scorpion is of and it makes my front wheels toe in and i think it is causing my steering to keep trying to self correct or straiten up so when the wheels are off the ground i turns from left to right on its own and won't stop. i like you r setup and if you could let me know the materials and process that would help alot.
08-03-2006, 02:58 PM | #9 | |
Someone said the steering rod is basically a clothes hanger.....so you can fab up your own pretty easily. The picture above is using RC turnbuckle rod ends and perhaps threaded rod. You can purchase the turnbuckle rod ends at towerhobbies.com and threaded rod at home depot or online as well. Last edited by muddeprived; 08-03-2006 at 03:02 PM. | |
08-03-2006, 03:06 PM | #10 |
The steering trim was the first thing i checked. i turned it all the way to both sides then evened it out. That was not the problem. that is a good idea to measure the back and the front i will try that. but also i can visalby see the toe in an the front if i put thr right tire completely strait thr left tire toes enough to be seen without measuring. yeh the front link i just a creap peice of metal and i think i need to replace it. i really like the look and set up on this jeep in the front that is why i would like to know how it was done. or if anyone else has a better set up i am open for all suggestions.
08-03-2006, 09:14 PM | #11 |
as for the steering motor being in the way wouldnt installing a real servo fix that |
08-06-2006, 12:32 AM | #12 | |
08-06-2006, 01:12 AM | #13 |
mine wont be an outer cage it will be the entire chassis with a 4 link front and rear |
08-06-2006, 02:47 PM | #14 |
Newbie Join Date: Jul 2006 Location: kentucky
did u have to weld the brake line to gether to make that? i want to make a skeleton for my new body on my nylint. but i dont know where to start. this way the weight wont crush the tiny lexan body.. and mostly for looks..
