09-26-2013, 05:18 PM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Kittanning
| Thinnest SLW Hubs..
im looking for the thinnest slw hubs. my reason for this is.. i am building a C3 on wraith axles and im trying to keep width down so im looking for the best wheels to keep my width like close to stock.. or maybe even + offset. i dont wanna be over 12inchs wide.. and i dont wanna cut my axle housings.. Whats my options? |
09-26-2013, 05:25 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: Thinnest SLW Hubs..
The narrowest hub is a .225". Those give you a pretty narrow track width with an SLW wheel. For the narrowest option, you can try to find some old VP neg offset slw's like Diamond D had on his Sportsman truck. Diamonds AR-60 sporty |
09-26-2013, 06:01 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
Lockedup rc does .185 slw hubs.
09-26-2013, 07:02 PM | #4 |
10.75 track width is very nice... Does anyone know if Locked up .185 on stock axles what the track width would be?
09-26-2013, 07:13 PM | #5 |
Rock Crawler Join Date: May 2012 Location: Washougal
You can also go with some losi scte style hexes that are a bit thinner than even the scx hexes. You should be able to get close to 11" wide depending on your tires. I can get mine to 10.625" with pitbull 2 tires, but that is with a carbon fiber face mounted wheel. Not very scale but oh well.
09-26-2013, 07:26 PM | #6 |
i wonder tho with what Rims.. i narrowed my choices to Locked up rims or motoworx.. im trying to track down the to closest to 11 or under (outside rim to outside rim)
09-26-2013, 07:51 PM | #7 |
I have some locked up wheels but they wont get you all that narrow. A 1" wide vanquish slw works out pretty good.
09-26-2013, 08:01 PM | #8 |
ok.. can u post some pics of what ur wheels look like posted? so i can see where the inside beadlock ring and steering link look like.. or does it all fit inside the rim?
09-26-2013, 09:14 PM | #9 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Pitbulls ver2 and Motoworks Talon beadlocks will be exactly 12" outside on AR60 axles.
10-02-2013, 11:16 PM | #10 |
stock wraith axles + TSS 2.2 Robby Gordon 1" beadlocks + LURC .185 SLW hub + thin 5mm SCX hex + 2.2 IRok tires = 11.25" track width about as tight as your gonna get and as narrow of a track. narrower tires would be the only thing left you could do to get it to 11" Last edited by STANG KILLA SS; 10-03-2013 at 07:26 AM. |
10-03-2013, 07:34 PM | #11 |
RC4WD makes a pin drive hub that has a SLW compatible bolt pattern. The holes just need to be tapped to 3mm. You can see more info about them in Crash's sporty thread in the Ridgecrest section. This is the narrowest setup out there...
10-03-2013, 07:44 PM | #12 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
You could look into these as well. Lattice Innovations Shift Hubs. Presenting Shifts, Lightweight n' Flexible Offset Hubs I believe they made a narrow version. |
