Thread: mix and match Currie axle widths?
Old 10-23-2013, 05:07 PM   #1
Default mix and match Currie axle widths?
Does anybody know the hex to hex widths available by mixing and matching wraith and scx-10 tubes? I think I need about a 9" width for the Big F-150 build I'm working on. Thanks for the help.
~Chip
WValtakis2 is offline   Reply With Quote
Old 10-24-2013, 10:59 PM   #2
Default Re: mix and match Currie axle widths?
Nobody's done this already? I searched and couldn't find anything...I would've thought the guys here would have been on this with the variety of bolt up widths available.
~Chip
Old 10-25-2013, 08:38 PM   #3
Metal shaper
I know that the short side tubes are near identical, that said, by swapping you will end up with Wraith width axles. If you want custom width, send us an email to carterfab@ymail.com. And no the XR tubes are not in sight from VP before someone mentions waiting on that option. We can set you up with any width imaginable.
CarterFab is offline   Reply With Quote
Old 10-25-2013, 09:35 PM   #4
Thanks Clay, so the wraith short tube is the same length as the scx10 tubes? I was hoping I might be able to lose a little width by using a wraith long with an scx tube. Just hoping for a bolt up solution instead of a custom setup, I'll keep you in mind
~Chip
mix and match Currie axle widths? - Similar Threads
Axle widths??? 6sharky9 General Crawlers 3 10-16-2013 04:30 PM
Mix and match question micro racer Axial Wraith 2 07-02-2013 04:54 PM
Mix & Match JunFac Beadlock Wheels tunis Tires and Wheels 5 11-20-2007 10:52 PM
Axle Widths gone_wheelin General Crawlers 11 08-20-2006 09:00 PM
