Thread: Axle Ratios Gmade/Wraith
Old 02-12-2013, 01:09 PM   #1
Default Axle Ratios Gmade/Wraith
Hi Guy's I'm thinking of putting a pair of Gmade Portals under my wraith. But I'm struggling to find info if they'll need different gearing?
My wraith is running full stock diffs and transmission on 2s and 35t and I'm not quite happy with speed not much top end. So thinking of a 2 speed Transmission aswell. And now I'm completely lost in ratios, gear choices and teeth.
Only if there was an app where you just punch in teeth on each section and overall tyre diameter to work out a speed would be majic
Can some one point me to a configuration or the overall axle ratios and transmission ratios and I can look for the maths.
Thanks Nick
Muddydisco is offline   Reply With Quote
Old 02-12-2013, 01:59 PM   #2
Default Re: Axle Ratios Gmade/Wraith
R1 R&P - 32/17=1.88:1
R1 Portal - 16/14=1.14:1
R1 Axle ratio - 1.88 * 1.14 = 2.14:1
Stock Wraith - 38/13=2.92:1
Looks like you're going to gain some wheelspeed with the R1 axles.
John82601 is offline   Reply With Quote
Old 02-12-2013, 02:08 PM   #3
Oh I would of guessed the other way around! So a 2 speed transmission will be great on stock 80/20.
Old 12-13-2013, 09:26 PM   #4
I know this thread is old but here is a link to something that might help you that you asked for in your first post. An R/C calculations conversion web page
R/C Calculations
lilbp12369 is offline   Reply With Quote
Old 12-14-2013, 09:43 PM   #5
Exclamation Re: Axle Ratios Gmade/Wraith
Originally Posted by lilbp12369 View Post
Definitely sticky material!
Wacki is offline   Reply With Quote
Axle Ratios Gmade/Wraith - Similar Threads
Wraith Gear-ratios?? SwampDawg Axial Wraith 13 07-15-2013 02:40 PM
Axle gear ratios ? DRV KRAWLER Formula Offroad 4 10-12-2011 03:57 PM
axle/tranny ratios soundcolor Losi Micro-Rock Crawler 1 01-31-2010 09:24 PM
Axle ratios - Kit, Overdrive, Underdrive sim Axial AX-10 Scorpion 59 11-08-2009 02:07 PM
atv axle ratios flybynighter Chit Chat 0 02-14-2009 12:56 PM
