RC4WD AX2 trans info I was just wondering if they were very durable,, and if you can shift well under full throttle? or do you have to stop to shift. I will be running brushless power not sure on size yet I'm thinking something around 3300kv thanks for any help. |
Re: RC4WD AX2 trans info Man I geuss nobody has run one of these ax2 trans? our they must be garbage. 93 views and not one reply crazy. |
Re: RC4WD AX2 trans info Nope, no one has one and Yup, garbage Since you don't want to search, here ya go 200+ posts that will answer almost any question you have about it http://www.rccrawler.com/forum/rc4wd...10-honcho.html |
Re: RC4WD AX2 trans info Thank you very much for quick reply I do appreciated it a lot my friend. My pc is form the year 2007 it is slower than hell and then some,, I did the search I got tired of waiting after a good 1/2 hour or so from being so slow I thought I would just ask the question from one of my fellow hobbyist I live on 1400 a month I'm disabled which my house payment is 1100 month includes taxes insurance another 100 go's to phone and I get 100 dollars a month to spend on RC parts the wife makes 2000 grand a month hopefully some day I can get a faster pc but for now all extra money go's to support hobby Thank you for taking the time showing me thread come right up with everything I wanted to know Your Friend and fellow hobbyist rjwalker |
Re: RC4WD AX2 trans info That transmission isn't garbage, but the Wraith doesn't need it. It doesn't have the suspension or the handling for high-speed driving, so it doesn't need multiple gear ratios to enable it to crawl *and* drive fast. The Yeti is a much more likely vehicle for that sort of thing. |
Re: RC4WD AX2 trans info I am going to or I should say I was. I'm putting in my mud bogger so I could shift between high and low for traction but the more I think about it probably would not be that reliable so I am just going to go with built ax10 trans. Thanks for the info though Quote:
Re: RC4WD AX2 trans info I use the AX2 in a couple of my trucks. Haven't broken anything yet. If your worried about running big power through it just buy the upgraded output shafts. You won't break after that"thumbsup" |
Re: RC4WD AX2 trans info I'm running the AX2 in my Wraith. Love it! :) |
Re: RC4WD AX2 trans info My son and I each run the AX2 in our Pro4 powered Wraiths. No problems to report. "thumbsup" EDIT: And yes you can shift on the fly. I feel the most important detail is to have a good radio that you can set the end points of the shift servo. We use the 4PL. |
