Thread: best value drive shafts
Old 11-01-2015, 07:22 PM   #1
Default best value drive shafts
hi again what would be the best value drive shafts with 5mm mounting to run on 2s and brushless i need four shafts for one rig thanks
steven318is is offline   Reply With Quote
Old 11-01-2015, 08:06 PM   #2
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Re: best value drive shafts
Just get MIP's. Don't skimp on driveshafts, it can ruin a whole day of wheeling. Get the AX10 (no dig) length and you'll save money.
Harley is offline   Reply With Quote
Old 11-01-2015, 08:32 PM   #3
MIP shafts are awesome, and will last a long time on 2s.
Jeepiac is offline   Reply With Quote
Old 11-01-2015, 08:44 PM   #4
are they as tuff as peple say? not too shure on lenght yet i have a t case on the way from russia, the wheel base should be around 12.5 to 13 inches its on a vaterra ascender frame and mini revo transmissions with drive shaft adapters that i had made. how about solid couplers for the trans to t case like the tf2 any one had any problems with slid couplers
Old 11-01-2015, 08:54 PM   #5
Pretty hard to break. If you're really worried get a rebuild kit. The pin and the joint on mine are real sloppy after a few years of hammer down abuse, but I have yet to break them. My brother and I have had issues with our Junfacs losing pins, but havent broken them either.
alpine4x4 is offline   Reply With Quote
Old 11-01-2015, 09:15 PM   #6
had considered the axial wb8 hd shafts found a set for 30 dollars delivered. but it seems the mip are my best bet so
Old 11-01-2015, 09:16 PM   #7
Mip is as close to indestructible as you going to find off the shelf.
68_f100 is offline   Reply With Quote
Old 11-01-2015, 09:59 PM   #8
MIP if you're okay spending, Traxxas shafts if you're on a tight budget. RC4WD steel punishers (original or rebuildable, not the V3) or Junfacs if you want a more scale appearance.
new2rocks is offline   Reply With Quote
Old 11-01-2015, 10:07 PM   #9
I run MIP's. I've lost more pins due to the joint getting hot and melting the red loctite than I've outright broken. I did break one bell but I'm sure it was due to a pin sliding out.
I need to try maxx shafts one of these days. I have all the parts to do it, I just need to find the time.
WHITE-TRASH is offline   Reply With Quote
Old 11-02-2015, 02:20 AM   #10
i had the maxx shafts from the emax on my other crawler found them hanging on every thing also i use the 2.5 maxx shafts on the rear of my racing slash 4x4 with the emaxx diff never had a problem with them on that but just wanted something bolt on this time for my new rig
Old 11-02-2015, 05:40 AM   #11
Best bang for ur $$$ is definitely JUNFAC. MIPs are Great but way over priced. JunFac are just as good an a 1/4 of the price.
Ohioskills is offline   Reply With Quote
Old 11-02-2015, 06:09 AM   #12
Axial WB HD shafts are very durable. I have blown up many other parts of my SCX10's drivetrain and the center shafts are still going strong.
svt923 is offline   Reply With Quote
Old 11-02-2015, 06:49 AM   #13
SSD makes these. I have no experience with them but they look tough and scale.
Old 11-02-2015, 08:26 AM   #14
MIP and forget about it!
winnerone23 is offline   Reply With Quote
Old 11-02-2015, 10:54 AM   #15
Jus
Axial HD WB's for $22 from RPP salvage yard. I've got a set of them on my wraith that has a tekin 6.5T 550 short course system in it.. It's seen a healthy dose of 3s and I've broken VP shafts and a ton of hex pins but the drive shafts are in perfect condition. That says a lot.
Jus is offline   Reply With Quote
Old 11-02-2015, 11:21 AM   #16
I have twisted those like a candy cane a few times. My experience mip is the best way to go. There not bulletproof, but as close as you can get.
littletoyboy is offline   Reply With Quote
Old 11-02-2015, 11:22 AM   #17
snapon boy's Avatar
Of you get mip shafts use dry silicone spray lube then put heat shrink over the set screw area over lap it a bit to help it stay in place.
snapon boy is offline   Reply With Quote
Old 11-02-2015, 04:53 PM   #18
This is what I do. And mainly from previous advice by the gentleman I quoting. I end up with the larger pin to grind down to size and only spend 35+ instead of 45+ for wraith mips
Thechewmaster is offline   Reply With Quote
Old 11-03-2015, 09:41 AM   #19
I run the JunFac shafts in my wraith, liked them so much I ordered a set to put into my tuber that I built. Can usually find them on Amazon or eBay for around 30 dollars for a set.
Bry73 is offline   Reply With Quote
Old 11-03-2015, 10:33 AM   #20
I used MAXX shafts on my 1/6th Jeep, it's a 13lb pig that goes nice and slow. I usually get a few years out of a set before the splines start to twist.
BigSki is offline   Reply With Quote
best value drive shafts - Similar Threads
AX10 MIP C Drive dig drive shafts in stock! RPP Hobby RPP Hobby 1 12-03-2009 10:50 PM
