Thread: Axles
Old 03-15-2016, 03:16 PM   #1
Default Axles
So I was hoping to get some input from the masses..
I am building a new truck based on the scx10 chassis. I am going for a scale look. Currently have the Proline dodge ram 1500 body. TowerHobbies.com | Pro-Line RAM 1500 Clear Body T-Maxx 3.3/Revo
1.9 Rock Creepers (3.8")
Long story short, I'm looking for a set of axles. I was hoping for the RC4WD T-Rex axles but the 4 link mounts are nowhere to be found on my time table.
So, should I buy a set of Yota II axles for $160 all hardware included?
Or
Piece together, at greater cost, the D60 cases from SSD with SSD Chubs, lockers, etc?
Are the Yota II axles beefy enough?
I go rock crawling / trailing. I use a 2 pole brushless motor. I am easy on my stuff.
Any input is appreciated.
robertjpjr is offline   Reply With Quote
Old 03-15-2016, 07:03 PM   #2
Default Re: Axles
Axial based axles for sure, much better quality.
gottorque is offline   Reply With Quote
Old 03-15-2016, 07:10 PM   #3
Default Re: Axles
TKO-10 axles from Ottsix IMO. great driveline angles by keeping your driveshafts up and out of the way, they look like a 1:1 Spider trax axle, and you can plop in durable axial gears. Much better axle clearance than the SSD d60's too.
2500hdon37s is offline   Reply With Quote
Old 03-15-2016, 11:16 PM   #4
Default Re: Axles
Why not AR60's?
Lordtuna is offline   Reply With Quote
