Thread: RJ speed body? Anyone use?
Old 07-05-2019, 03:59 PM   #1
Default RJ speed body? Anyone use?
Happened to be looking at bodies cause I'm bored and found the "RJ speed 80s pickup" body and it has an uncanny resemblance to a CJ of sorts. Wondering if anyone has used this body on a crawler of any kind. I can't seem to find wheelbase measurements, but overall its 15 inches so I have to think it would get close enough to work with. Pics if you've used or seen it?
DukeMinnix is offline   Reply With Quote
Old 07-05-2019, 04:26 PM   #2
Default Re: RJ speed body? Anyone use?
Google images search. One of the first results gave this. Scrambler body
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 07-05-2019, 04:47 PM   #3
It's on the small side for sure. I've used it on a CC01, and while the wheelbase worked out it was too narrow for the track width. It's about 160mm wide or so and about a 10" wb.
Still have it, can you get some firm measurements if you need them.
OSRC is offline   Reply With Quote
Old 07-05-2019, 07:32 PM   #4
Like OSRC said its narrow and definitely a short wheel base body. Would look great on an barrage or mst cmx. Even tho their website says it will fit an axial scorpion (og ax10). it looks monster truckish/ mega mud truckish
They also make a 70's jeep body too.
RJ Speed
hillbillyrc is offline   Reply With Quote
Old 07-06-2019, 07:37 AM   #5
I meant mounted, I found those pictures but it didn't do anything for me as far as how it would actually look on a truck
nah, not necessary, It's becoming obvious it may do for a comp body or something but not what i'm going for.
RJ Speed
I saw that body but the width looks to be about the same and same issues exist as above. Oh well, onto the next hairbrain idea
Old 07-06-2019, 07:56 AM   #6
There are 2 mounted pictures, that's why I linked it. They aren't great pictures, but the only ones I saw and it has replies from people with the body
Old 07-06-2019, 08:10 AM   #7
my bad I didn't see any mounted pictures, just the blue unmounted ones and some photobucket not working images.
RJ speed body? Anyone use? - Similar Threads
Xtra Speed body Frank211 Paint and Body 7 06-10-2018 02:28 PM
RJ Speed Jeep body. 02tac Paint and Body 0 01-28-2011 10:08 AM
wb for rj speed body? jetboat Paint and Body 0 09-27-2010 03:17 PM
